Distributor on a 57 Olds
Old Aug 26, 2010 | 04:17 PM
papas88's Avatar
I'm a bit confused. I can't seem to find what holds the distributor in place. The manual says loosen the clamp and pull it out, but I don't see the clamp. I have a spare engine as well and don't see anything on there as well. How in the world do you adjust timing, let alone remove the distributor?
Thanks...
Old Aug 27, 2010 | 03:03 AM
Yellowstatue's Avatar
The clamp should be at the base of the distributor on the drivers side, bolted to the block...if you don't have a clamp then you need one...without the clamp, the distributor might turn randomly...it should rotate freely to adjust the timing- if it doesn't turn it is stuck and you will have to free it up...
Old Aug 27, 2010 | 07:06 AM
papas88's Avatar
Thanks Yellowstatue,
I'll take another look this weekend.
Old Aug 27, 2010 | 08:30 PM
59-59-59's Avatar
They usually take a 9/16 socket..Distributor wrench or getting creative with extensions that swivel would help
Old Aug 28, 2010 | 08:15 AM
papas88's Avatar
Found it... and it was staring right at me all along. I guess I just didn't know what I was looking at. Thanks for the help!
olds70supreme
Sep 10, 2012 07:33 AM
chris83
Aug 18, 2012 01:47 PM
1964F85
Feb 21, 2010 05:25 PM
Bosco1956
Oct 17, 2008 09:57 PM
rroth01
Apr 23, 2008 07:03 PM
