Diff plug removal tool
Old October 10th, 2024 | 04:13 PM
72455's Avatar
Does anyone make a special tool to remove the diff fill plug on a '72 A body 10 bolt rear?
Old October 10th, 2024 | 04:25 PM
Dave - Yours isn't a 3/8" socket drive? Is yours Torx type?
Old October 10th, 2024 | 04:29 PM
Doesn't look like this I guess which accommodates a 3/8" socket drive?
Old October 10th, 2024 | 04:52 PM
Horsepower's Avatar
Show me a picture
Old October 10th, 2024 | 05:55 PM
72455's Avatar
Originally Posted by Horsepower
Show me a picture
Yep..it looks like the one Norm pictured above. I've been using a 3/8 drive ratchet with a short extension, but it's a bit cumbersome, so I was wondering if there was perhaps a special tool made that maybe would be a bit easier.
Old October 10th, 2024 | 05:59 PM
Rallye469's Avatar
The correct tool is an air chisel aimed at 2:00, when you strip that plug out.
Old October 10th, 2024 | 06:06 PM
Line up the socket ratchet extension well on center, provide a couple good wraps w/ a hammer. I've seen socket drive extensions containing the small lock "ball" be so filled w/ gunk/grease/rust/paint, etc. the lock ball doesn't budge - ensure the socket extension if it has such a ball is clean w/ freedom of movement. Smack it w/ light blows of a hammer - it should go in. Good Luck!
Old October 10th, 2024 | 06:07 PM
That's good stuff right there.
Old October 10th, 2024 | 06:08 PM
72455's Avatar
Ahhh...I'll try that next time
Old October 10th, 2024 | 06:09 PM
Dave - Use a small bugger - no longer than say ~3" - 4" extension. Several whacks it should pop in.
Old October 10th, 2024 | 06:22 PM
72455's Avatar
Norm-I think the one I use is a 3"
Old October 10th, 2024 | 06:25 PM
I use a 1/2" > 3/8" adapter. Short, fat and easily whacked.
Old October 10th, 2024 | 06:31 PM
Then I pop a 2' long 1/2" breaker bar into that 1/2" > 3/8" adapter.
Old October 10th, 2024 | 06:38 PM
66_Jetstar's Avatar
If its rusty or has a thick layer of paint, it pays to scrap the square hole out with a pick or flathead. That build up can make them easy to strip. If it hasn't been out in awhile then put the torch right to it.
Old October 10th, 2024 | 06:48 PM
72455's Avatar
Does that give you enough reach, or do you still need an extension?
Old October 10th, 2024 | 06:58 PM
Yes, as I recall. If not, it gets an extension. I am not lacking in 1/4" >< 3/8" >< 1/2" adapters, extensions & 45° swivel adapters.
Old October 11th, 2024 | 03:38 AM
I bought this pipe plug socket set. Ford uses a 3/8" male pipe plug to adjust the intermediate band on the side of the C6 in my 86 F250.
Grey Pneumatic Grey Pneumatic
Old October 11th, 2024 | 07:56 AM
zl1 camaro's Avatar
Originally Posted by rallye469
the correct tool is an air chisel aimed at 2:00, when you strip that plug out.
:d
exactly, been down that road many times. Had to comment on this.... Lol
Old October 11th, 2024 | 09:18 AM
I've found that an impact wrench is a good way to loosen rusted plugs like this without damage.
Old October 20th, 2024 | 01:38 PM
72455's Avatar
So I took your advice Norm and invested in a pipe plug removal tool. I also knew that from the last time I took the plug out that it felt kinda beat up, so I replaced that as well.
Old October 20th, 2024 | 03:14 PM
I also knew that from the last time I took the plug out that it felt kinda beat up...
Ya think? LOL
Old October 22nd, 2024 | 04:11 PM
Clean the gunk from the hole in the plug. Use a 3/8 extension, or ideally the proper 3/8 square drive socket. Give it a couple of good hits with a hammer, then try to remove it. If it comes out, great. If not, get the smoke wrench. Heat makes every bolt easier to remove.
Old October 22nd, 2024 | 05:43 PM
Matt - Dave said he replaced the plug.
NorthBay72supreme
Drivetrain/Differentials
July 1st, 2022 07:53 AM
scrappie
October 5th, 2019 07:17 PM
Freddy B
August 18th, 2015 10:50 AM
jtdb153
May 26th, 2015 01:30 PM
Caveman-455
May 7th, 2012 06:49 PM
