Did some clean up work...
Old Mar 23, 2019 | 11:37 AM
72455's Avatar
1972 U code Supreme
At some point in one of it's former lives, my 72 Supreme had been switched from a side mount battery to a top mount, so it was time to go back to a side mount, and it really cleaned things up.
Before..
..and after
Old Mar 23, 2019 | 02:23 PM
I was never a fan of side mount batteries. The mountings were to persnickety, corrosion was hard to control, or the lugs stripped.
Old Mar 23, 2019 | 02:26 PM
Not to mention hard to get jumper cables to hold on, or even battery charger clamps.
Old Mar 23, 2019 | 03:03 PM
^^x2^^
^^x2^^
Old Mar 23, 2019 | 03:04 PM
That too...
Old Mar 23, 2019 | 08:15 PM
Personal experience from many years of working in auto parts stores and full service gas station back when those existed.
Old Mar 23, 2019 | 08:19 PM
72455's Avatar
1972 U code Supreme
No worries here...I did my research and the terminals I used have 1/2 inch heads on the bolts, not the 8mm standard size.
Old Mar 23, 2019 | 08:24 PM
The standard metric size battery terminal bolt is a 10mm. Personally, I have never seen an 8mm metric standard size battery terminal bolt.
Old Mar 23, 2019 | 08:25 PM
To me, the minor inconvenience of side post batteries is worth it. After seeing the fireworks that result from laying a wrench across the posts, at the very minimum protective covers are a requirement. Maintain the charging system,and you won’t need to jump start the car. I do have a battery tender on my car for when it sits for a long period, I made a plug to make connecting it quick and easy.
Old Mar 23, 2019 | 08:28 PM
And I’m pretty sure the “8mm” cable bolts are actually 5/16. I prefer to keep my old iron SAE fractional if at all possible. With the possible exception of the 9mm ammunition, I never really embraced the metric system. 😎
Old Mar 23, 2019 | 08:33 PM
Correct. 5/16 = 7.938
Old Mar 23, 2019 | 08:38 PM
Yeah, I guess I'm remembering when these cars were daily drivers and folks would have the battery drain due to leaving the headlights on, an interior light on, the glove box door or console door open, etc. Lots of things resulted in a depleted battery besides a defect in the charging system. I can't count the number of time I jump started cars in the school parking lot, the grocery store parking lot, the mall, or the gas station where I worked.
Old Mar 23, 2019 | 08:41 PM
72455's Avatar
1972 U code Supreme
8....10....either way, the ones I used are 1/2 inch.
Old Mar 24, 2019 | 03:37 PM
Dave,
You did a nice job. My 72 at one point also had surgery to replace the battery connections. Likely it needed a battery in the boonies and there weren't a lot of those side posts available there at the time. Snip snip and top post connections were installed.
Looks like you also bought a new battery? Which vendor did you use for the reproduction battery cables?
What is that brace doing in your engine compartment?? That looks like something that was added by a PO. The only Olds A body cars that had fender braces in 70-71 were the Vista Cruisers, but their braces went the exact opposite to what I see in your pictures.
Old Mar 24, 2019 | 05:23 PM
72455's Avatar
1972 U code Supreme
Originally Posted by Allan R
Dave,
Thanks Alan. I actually bought the top mount battery last summer and swapped it out yesterday for the side mount. IRF to your question about the cables, I didnt buy new ones. I just bought new terminals when I swapped in the side mount battery.
Now, about those fender braces...I don't know what to tell you. I just assumed they were factory and never questioned it. They look like they belong, so I'm good with them. But it is good to know should I decide to go back to stock. Can you think of any reason why a PO would have installed them? Maybe for support when it was built for the strip...???
Here's the best pic I have right now ..maybe it will help...the end you can't see bolts to the top of the radiator supoort just to either side of the radiator.
Old Mar 24, 2019 | 05:42 PM
Dave, ya know what that brace looks like? A front bumper support that's been re purposed by the PO. Just an FYI, where it's positioned now it's of no value to the fender. In fact it will create a force vector that may be dangerous if the car is ever hit on the front. You probably had to remove it to install the battery??
Old Mar 24, 2019 | 07:32 PM
72455's Avatar
1972 U code Supreme
I didn't have to remove it, but I did have to swing it out of the way. Should I get rid of them?
Old Mar 25, 2019 | 01:16 AM
Front-end after market fender braces are designed & installed to increase the triangular rigidity of the front-end of a vehicle's sheet metal alignment. They've been around many, many years. Yes, there are areas to manually align hood bumpers, hood hinges/springs, door alignment, etc. Yet, front-end fender braces often afford long-term benefits of maintaining alignment with fenders to doors, fenders to bumpers, fenders to hood, fenders to cowling, etc. Most often the application is better suited to vehicles which receive significantly more continual cornering stress. I highly suspect there is no danger involved in maintaining the front-end fender braces. The brackets should allow you to maneuver them slightly - forwards/backwards, left & right - with slight sleeve openings to adjust for better fender alignment. I'll note however, it appears those are lower front-end fender braces. In any case, if they perform the function of maintaining front-end triangular rigidity & alignment (and removing any sloppiness in the total front-end) I'd leave them attached.
Old Mar 25, 2019 | 01:46 AM
72455's Avatar
1972 U code Supreme
Hey Norm thx for the comment. I'm not sure about where they bolt to the fender, but I do know that the end that bolts to the radiator support has an elongated slot about 3/4 inch long that would give me some adjustment. If they were bumper braces as you and Allan suspect, would they have the slots?
Old Mar 25, 2019 | 04:19 AM
Dave- I never referred to them as bumper braces. See above. And, I’m not certain if they are bumper braces as Allan suggests. I’d need to look at my vehicle. Additionally, I can’t see the entire brace so I can’t comment on any slots but generally they do have some slot/sleeve wiggle room. Many styles are available, I believe Fusick, GM Parts, etc. sell them. Many people made their own.
Old Mar 25, 2019 | 04:26 AM
I can already see where your current fender brace is attached to the fender. Not sure about your question?
Old Mar 25, 2019 | 04:32 AM
72455's Avatar
1972 U code Supreme
Oops...my bad...it was 430 this morning when I posted that...coffee hadn't kicked in yet..lol
I'll take some better pics when I get the chance.
Old Mar 25, 2019 | 04:34 AM
72455's Avatar
1972 U code Supreme
It's the other end that you can't see that is slotted. Once I post more pics, you'll see what I'm talking about.
Old Mar 25, 2019 | 05:04 AM
That is a interesting brace. At first just casually looking thru the thread, I thought that was a fender brace for a 78 up Cutlass, seems like I've seen them before. But looking back i see we are working on a 72 Cutlass? I also have never seen one like that on a 68-72. ???
Old Mar 25, 2019 | 05:10 AM
Hey 72455 maybe you can start another thread asking what that brace is and others will respond. The title of this thread sounds like you are cleaning your car and some may just pass over it. But everyone loves to take a shot at a question. I wouldn't take them off, looks too perfect to be something the PO made. Greg.
Old Mar 25, 2019 | 07:04 AM
72455's Avatar
1972 U code Supreme
Thx for the suggestion Greg. I'll do that once I take better pics.
Old Mar 25, 2019 | 09:59 AM
Greg, that brace is from a 71-72 A body front bumper - I'm positive.
Dave - the braces have slots so the front bumper can be positioned and the brace tightened to the bumper and frame. Does the other end look like one of these long ones??
I also think if the CS and lower models needed those braces, they would have been installed from the factory. Note the length and position of the braces for the VC I posted earlier. I would ditch them as they don't really serve any practical purpose.
Old Mar 25, 2019 | 10:48 AM
72455's Avatar
1972 U code Supreme
The ones I have look like the third set from the top in your pic, but if those ones are for the VC, then they're not the ones I have, as mine are too short to go from the rad support to the firewall.
Old Mar 25, 2019 | 03:05 PM
No Dave, those are the front bumper braces for ALL the Olds A bodies in 71/72. And yes that includes VC. But the VC had different braces for the cowl to rad support. You should look and see if your car is perhaps missing a set of braces on the front bumper. There should be six of them holding the bumper in place.
Old Mar 25, 2019 | 03:15 PM
72455's Avatar
1972 U code Supreme
Where would they be Allan?
Old Mar 25, 2019 | 04:02 PM
  #31
Attached to the front bumper and bracket bolted to the frame rail. Look in your 72 Cutlass Assembly Manual - Section 14 page 100
Old Mar 25, 2019 | 04:21 PM
  #32
72455's Avatar
1972 U code Supreme
I don't have an AM...would be in the CSM or body manual?
Old Mar 25, 2019 | 07:05 PM
  #33
72455's Avatar
1972 U code Supreme
I continued the discussion about the braces on another thread...
Old Mar 25, 2019 | 08:48 PM
  #34
w-30dreamin's Avatar
71 & 72,now I want a 68
I agree
They may not be factory installed but I doubt they are hurting anything as far as safety. They add to the cars personal story,character.
FStanley
Feb 28, 2023 02:48 PM
Oldssupreme
Jul 29, 2017 01:52 PM
pogo69
Hurst/Olds
May 18, 2015 08:06 PM
Tedd Thompson
Feb 21, 2015 08:43 AM
VikingBlue
Feb 11, 2012 10:24 AM
