Did Olds make a Cruise for 66 cutlass?
Wonder no more. You can find the answer to that and much much more at Wild About Cars. The SPECS booklet, for example, lists the available options:
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
You'll see option K30 Cruise Control shown there.
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and the Automotive History Preservation Society library growing daily.
Free to join, free to learn.
Cruise was first offered on the A-body line in the 1964 model year. The 64 Vista that I just bought has factory cruise. The 64-66 unit is unlike those of later years, in that it uses a thumbwheel on the dash to set the desired speed. A bowden cable runs from that control head to the cruise unit on the LH inner fender, which moves a lever that sets the rotational speed at which a set of governor contacts spun by the speedo cable opens or closes an electrical contact, which then drives the motor that moves the throttle arm on the carb.
Joe could you comment on the differences from 66 to 67? I have most of a 67 setup, and a complete 66 setup, and want to complete the 67 setup using compatible stuff from the 66, and put it on my 67.
Sorry I can't be of more help.
Henry
From what I can tell, the only difference between the two is the control stick. The 66 has a button below the dash, and the 67 has the button on the end of the turn signal lever. I believe the bellows, the throttle chain, the speedo cables, the vacuum lines and can, and the transmission are the same.
I am generally one for originality, but when it comes to cruise control, modern aftermarket kits make a lot of sense. They now have an electronic speed transducer that screws onto the speedo cable output on the trans, no more magnets or other crap. I have seen one supplier that offers a replacement turn signal lever with the needed switches that fits the old turn signal switch and looks factory. Less than $300 and simple to install.
Tim
Tim
Sporty45
August 17th, 2015 04:21 PM
0371richwiner
May 10th, 2013 06:44 PM
