Decoding Transmission production days...
What day is day number one for a transmission. Mainly for the 1970 turbo 350s
Basically looking for a transmission that would be the same week as what the Rallye was made to keep it all kinda numbers matching. Mine was built in the 3rd week of Feb 1970 and I have no clue what production days to look for or anything.
PLEASE HELP!!!!!
PLEASE HELP!!!!!
PLEASE HELP!!!!!
PLEASE HELP!!!!!
The last digits stamped on the transmission ID tag were a serial number. I think they started with 1001, but I've heard of 3-digit numbers, so who knows.
Each transmission type had its own sequence of serial numbers. What I mean is that there is a serial number 1045 for each of OD, OG, and OW transmissions. So the factory might have built 500 OG transmissions on September 5, numbering them 1001 through 1500, then on September 6 built 300 OD transmissions, numbering them 1001 through 1300. Then on September 7 they might have switched back to OG and resumed the numbering at 1501.
As far as which number would best line up with your car's build date, I'm not sure that's possible. I've been trying to correlate 1970 OW transmission serial numbers to build dates and so far it appears pretty random. The final assembly plant probably received regular shipments of transmissions and put them in a holding area until needed on the line. I doubt these holding areas were a straight line guaranteeing first-in-first-out.
I'd love to hear from anyone else with knowledge of this issue.
I have also heard what Brian said and starting with 1001 with the trans numbers. I have never seen any OW trans number under 1XXX though. Most W30s I have records of seem to have at least a close correlation to the VIN/build date and sequence number of the tag but nothing in exact order as Brian has said.
gearheads78
July 14th, 2008 12:47 PM
