Decoding Transmission production days...
Old Jul 9, 2013 | 08:44 PM
sicky olds's Avatar
NôôB
What day is day number one for a transmission. Mainly for the 1970 turbo 350s
Basically looking for a transmission that would be the same week as what the Rallye was made to keep it all kinda numbers matching. Mine was built in the 3rd week of Feb 1970 and I have no clue what production days to look for or anything.
PLEASE HELP!!!!!
Old Jul 9, 2013 | 10:37 PM
stevengerard's Avatar
PLEASE HELP!!!!!
They have a VIN derivative on them so you can look for a trans that is close to your VIN. I'd say since they do have a VIN number on them is it worth worrying about a date match. Anyway you look at it it will not be a number matching trans. What I mean is it isn't the same as finding a replacement carb, starter or distributor, the VIN on the trans will tell you it doesn't match.
Old Jul 9, 2013 | 10:43 PM
sicky olds's Avatar
NôôB
I understand that but i would like to get as close as i can to make it to numbers matching.
Old Jul 10, 2013 | 03:04 PM
BlackGold's Avatar
The last digits stamped on the transmission ID tag were a serial number. I think they started with 1001, but I've heard of 3-digit numbers, so who knows.
Each transmission type had its own sequence of serial numbers. What I mean is that there is a serial number 1045 for each of OD, OG, and OW transmissions. So the factory might have built 500 OG transmissions on September 5, numbering them 1001 through 1500, then on September 6 built 300 OD transmissions, numbering them 1001 through 1300. Then on September 7 they might have switched back to OG and resumed the numbering at 1501.
As far as which number would best line up with your car's build date, I'm not sure that's possible. I've been trying to correlate 1970 OW transmission serial numbers to build dates and so far it appears pretty random. The final assembly plant probably received regular shipments of transmissions and put them in a holding area until needed on the line. I doubt these holding areas were a straight line guaranteeing first-in-first-out.
I'd love to hear from anyone else with knowledge of this issue.
Old Jul 14, 2013 | 09:24 AM
I have also heard what Brian said and starting with 1001 with the trans numbers. I have never seen any OW trans number under 1XXX though. Most W30s I have records of seem to have at least a close correlation to the VIN/build date and sequence number of the tag but nothing in exact order as Brian has said.
J-(Chicago)
Mar 22, 2009 12:06 PM
wolfman98
Feb 3, 2009 05:47 AM
gearheads78
Jul 14, 2008 12:47 PM
bayer20
Mar 3, 2008 05:10 AM
