Dealer Installed Vinyl Top
What's everyone's thoughts on restoring a car back to original with a dealer installed vinyl top? Have a red 70 Sport Coupe with a white top but the trim tag translates to a painted red roof . Unfortunately there isn't a invoice from the dealer proving it left the lot this way. No options except the OAI hood, radio, remote mirror and power steering. First thought was to keep it off but starting to have second thoughts. There's no rust so not worried about the bad stigma vinyl tops get but wondering what thoughts other enthusiasts have.
Dustin
Dustin
Decide whether it's easier to install a new vinyl top vs filling holes and metal finishing where the outline mouldings were. If dealer installed (and that was common), the mouldings were probably installed with screw studs.
Thats because of the penny pinching bean counters couldn’t justify the extra money for primer/paint under the vinyl top. Can’t say I really blame them, let’s say each car with vinyl would cost an extra 5 bucks in materials to paint something that would never be seen. Five bucks doesn’t sound like much, until you multiply that by a few millio cars. Before long, your talking about real money!
I think vinyl tops look great on certain cars.
My opinion is the 68 - 72 Olds A body had the sexiest rear flank of any production car made. The vinyl top just breaks up all that sex appeal in a bad way. Leave the vinyl top off and get your mojo back...
tc
tc
Small strip of bed liner removed showing original paint below (you can also see the original lacquer where the trim has been removed beween the new base-clear paint and white spray-on bed liner):
Most of the driver side bed liner removed:
Top cleaned down to bare metal:
New top on (yes I painted the bare metal before putting on the new top):
Personally, I like the vinyl top and would leave it on.
Rust hoarders, that's a good term since that's exactly what they did. I had my 79 Calais re-painted in 2002 and I had to come back 2 years later for rust repair under the top. It was so extensive it cost $1800 to repair and that was 2004 dollars. You see this alot with the landau vinyl tops of that era, the rot travels right down the fixed rear window into the qtr panel.
It will probably get painted like it left the factory but will keep the trim in case an old pic from a prior owner surfaces. Not worried about rust since it survived this long w/o rust. Noticed in past restorations the factory was stingy with paint under the vinyl top. Also have seen seam sealer instead lead to fill the quarter panel to roof seams to save time or money. My own opinion is vinyl tops look great on most vehicles but got a bad wrap from rust issues. Makes you wonder how the assembly line didn’t get slowed down when a a couple of vinyl top cars were going down the line.
That's what killed my 1970 Supreme. I removed the viyl top durnig the first paint job and repair effort, replacing the entire panel below the rear window, but the rust came back years later.
If like them, as said, do rust prevention and paint possible. I would bet on the assembly line, certain people probably did the vinyl tops and got very efficient at doing them.
midnightleadfoot
March 27th, 2018 08:57 AM
