Data Plate Unreadable by Paint
Old Jan 11, 2024 | 09:12 AM
MGBill's Avatar
What is the best way to remove paint from a data plate without doing any damage to it. I do not want to remove it from the car.
Old Jan 11, 2024 | 09:30 AM
Charlie Jones's Avatar
Phantom Phixer
A chemical paint remover such as Zip-Strip should do the job.
Old Jan 11, 2024 | 09:31 AM
Rallye469's Avatar
Paint stripper.
Do not use an abrasive of any kind.
Old Jan 11, 2024 | 08:12 PM
cherokeepeople's Avatar
why not try the old paper and pencil tracing
Old Jan 14, 2024 | 06:58 AM
gs72's Avatar
72Cutlass S
DOT 3 brake fluid will soften and lift the paint. Just use it sparingly so it doesn’t effect the area you want to keep painted.
Old Jan 14, 2024 | 12:01 PM
Supernice88's Avatar
Art S
Acetone, wet a rag then wipe across the surface, it evaporates fast so it might take a few wipes. I would wipe off just enough to be able to read what's on it.
Old Jan 14, 2024 | 07:31 PM
Let it soak
Old Jan 15, 2024 | 05:08 AM
Andy's Avatar
Clean it and the area around it, tape off around it good and simply use paint remover..brush on, let sit, wipe off with disposable rag, repeat till its clean..may take two possibly three times..then wipe it off with paint thinner or acetone, easy peasy
YukonOlds
Aug 31, 2023 02:41 PM
Rca
Jul 4, 2023 06:22 AM
vincet
Nov 8, 2022 04:44 AM
oneowner
Nov 23, 2019 06:43 AM
'69CutlassVert'
Nov 3, 2014 11:38 AM
