Dashpot adjustment question
Old May 4, 2013 | 09:35 AM
Al Sanchez's Avatar
Okay, at first I did not know what this thing was or what it do. After reading some posts on here I found out that it was called a Dashpot and I have a little idea on what it is supposed to do. My question is how do I know if this thing is working or not? I don't see any wires or vacuum hose that you can connect to it does this thing just have a adjustment ? If it does how do I know what to adjust it to. Any help would be appreciated
Old May 4, 2013 | 09:42 AM
If your engine doesn't stall when you let off the gas quickly, especially with the A/C on, then it's working.
Adjustment information is in the Chassis Service Manual for the year in question.
Old May 4, 2013 | 09:51 AM
Al Sanchez's Avatar
No my car not stall when I let of the gas quickly as I have been doing that alot since I replaced my carburetor, as for when my A/C is on I have not had a chance to try it because my A/C keeps blowing the wierd looking fuse I think it's called the thermo fuse. But this the next thing I need to work on.. And I do need to get me a service manual for this car..
Old May 4, 2013 | 10:12 AM
442Harv's Avatar
Al,I keep blowing that fuse, had to recharge the system, to fix it.
Old May 4, 2013 | 10:19 AM
Correct - that fuse is designed to blow if the pressure in the A/C system is too low.
You'd think they would have been happy with a switch that just turned it off, but No...
Old May 4, 2013 | 10:57 AM
Al Sanchez's Avatar
Yeah an On/Off switch would have been geat because I'm tiered of buying those dam thingsi blew like five already i recharge the system and it worked for like three days then it blew that fuse, my brother works on A/C systems and thinks my O ring seals might be weak and I might need to replace them, he also has the R12 I need so I guess I'm lucky there, then I can adjust and see if my dashpot works
Old May 4, 2013 | 11:00 AM
I'd rewire it so that it turns off the compressor like a modern low-pressure switch.
Old May 4, 2013 | 11:08 AM
Al Sanchez's Avatar
Exactly what I told him, something the new systems might have,he said he can eliminate it but I still want some sort of fuse or switch so it don't burn my compressor, just not a 4 or 5 dollar one
Old May 4, 2013 | 11:24 AM
Lady72nRob71's Avatar
That fuse opens up after a certain time of the compressor running with too little charge.
If you have to keep charging it, it is better to find and fix the leak.
Never bypass this fuse for the sake of your compressor.
The dashpot can be adjusted (screwing it in or out of its mounting bracket) as per a procedure int he chassis manual.
If you are not having stalling issues with the AC on and throttle released, then it is probably doing fine.
Old May 4, 2013 | 11:38 AM
Al Sanchez's Avatar
I don't think I want to bypass it or remove it, I will try to find the leak and fix it, then I can adjust the dashpot because I know it's not adjusted right because I moved it, I have a fisher body service manual but I think I got the wrong one it does not have anything on the engine only body and electrical
Old May 4, 2013 | 11:46 AM
The Fisher Body Manual covers the body.
The Chassis Service Manual covers the chassis.
Old May 4, 2013 | 11:52 AM
Al Sanchez's Avatar
Okay I got the wrong one, I thought this one covered everything since it's a pretty thick book, I guess I need to get the chassis one.. Thanks
Old May 4, 2013 | 12:33 PM
Dashpot adjustment -
Choke fully open, idle speed set correctly, fast idle cam off all steps (normal idle position).
Depress dashpot stem all the way with needle nose pliers. Should have 0.06" between dashpot stem and carb lever.
Rotate dashpot until clearance is met, then tighten locknut.
Old May 4, 2013 | 01:45 PM
Al Sanchez's Avatar
I have not gone out to the garage to check but when you say Deprees you mean that if I grab it with some needle nose pliers and I pull on the dashpot stem it should still come out some? And if it does I should adjust it to 0.06 is that what you mean
Old May 4, 2013 | 06:49 PM
No, do not pull on the stem, push it IN. It is spring loaded. Hold it in all the way down and rotate it until you get the 0.060 clearance. Use feeler gauge for checking the gap.
Basically all it does is "pads" the last little bit of a released throttle, slowing its return a little.
Old May 4, 2013 | 06:57 PM
Al Sanchez's Avatar
Okay.. I got it now, I know what you mean, it make sense... Thanks
Old May 4, 2013 | 07:30 PM
Great - let us know how it goes.
Now, for a little dash o' pot............
Old May 8, 2013 | 11:36 AM
ddd777's Avatar
Illustration of Dashpot Adjustment
From the 1972 Service manual 6M-38
Mine is broken....anybody got a spare?
File Type: png
mmurphy77
Dec 5, 2011 05:47 PM
Del70
Nov 20, 2011 11:26 AM
Del70
Sep 8, 2011 04:41 PM
68Tom
Nov 15, 2010 09:33 PM
68Tom
Nov 14, 2010 07:22 PM
