dash pad removel
Old Mar 25, 2020 | 07:59 AM
oldsdriver1218's Avatar
dash pad removel
does anyone have experience removing the dash pad from a 1971 cutlass placement of nuts that need to be removed and how many
Old Mar 25, 2020 | 09:32 AM
AJFink's Avatar
1. Do you have the service manuals and the assembly manual?..........these will show you were all the nuts are and what plugs you will need to unplug and so on. One spot just above the light switch is a push nut that just grips the threads of the stud that is threaded into the dash. you will have to be careful here because you can break off the stud and plastic base. You will be removing the entire dash be prepared to have a lot of patience, this is not easy but do able.
I can't express the importance of #1. The assembly manual for sure.
This will be a good quarantine project Good luck
Old Mar 25, 2020 | 10:10 AM
https://thisoldscar.wordpress.com/20...-part-i-of-ii/
https://thisoldscar.wordpress.com/20...part-ii-of-ii/
This should help you. Nice and easy to see/understand pictures of actual dash removal
Old Mar 26, 2020 | 09:01 AM
thanks I actually have the manuals on disk and just looked through them a little veg but will help
Old Mar 26, 2020 | 09:04 AM
this will help the pictures will make thing a lot easier as they say a picture is worth a thousand works I know I will be referencing the links often much appreciated
RonFX
Jan 7, 2018 05:01 PM
super88man
Jul 14, 2016 10:47 AM
Billyboy746
Jul 16, 2014 08:49 PM
anthonyP
Feb 14, 2014 11:25 AM
HARDCORE POSER
Aug 26, 2010 05:45 PM
