Dash molding
Old Mar 8, 2021 | 01:36 PM
BobPlouhar's Avatar
Dash molding
1970-72 chrome plastic strip molding insthall from parts place looks like have to drill 1/8” hole for push in pins with glue any input would be nice
Old Mar 8, 2021 | 02:42 PM
scrappie's Avatar
You dont have to drill anything. Dont drill because you will create a problem. The barbs are designed to push through and secure the molding. The material is very thin and the pins push in with very little pressure. The only thing I would do is heat the molding with a heat gun so it is more pliable. I wouldn't even use glue.
Old Mar 8, 2021 | 04:47 PM
Loaded68W34's Avatar
Don't use glue, it will just make a mess. Did your pad have a molding on before? If so, just take the old pins out and insert the new strip with pins in their place. If you see glue on the pad, it is likely because someone tried to glue on a molding that was falling off.
Old Mar 9, 2021 | 05:49 AM
Jungle Cat's Avatar
If my memory serves me correctly 70 was glued on and the push pins were on 71-72?
Old Mar 11, 2021 | 03:09 AM
scrappie's Avatar
I heard that too
Old Mar 11, 2021 | 07:29 PM
WTHIRTY1's Avatar
Escape From The Ordinary
Originally Posted by scrappie
I heard that too
Correct-ish. From the factory, the '70 molding is glued on and the later years use the plastic push pins. There is a service bulletin published in '70 (would need to double check on the exact date) that covers this and IIRC suggests using the clips. The NOS molding included a pack of the push pins in the box.
Old Mar 12, 2021 | 07:36 AM
Interesting, I did not know that. I wonder if the early 70 moldings were made differently with a flat backside instead of a groove?
cfair
Jul 2, 2019 12:11 PM
71cutlass_ragtop
Mar 22, 2019 05:06 PM
wisniows
Jun 19, 2015 05:07 PM
LI Olds
Jul 11, 2012 05:27 PM
Aceshigh
Jul 1, 2009 12:13 PM
