Das part
Old Oct 30, 2023 | 04:33 PM
marxjunk's Avatar
Das part
Is this repopped? Where or who? I cant find one.its just the inside piecr and not the cowl
Old Oct 30, 2023 | 06:11 PM
cfair's Avatar
I don’t know much about the A bodies, but all the fixes I’ve ever seen involve custom welding.
To avoid that see if you can find such a part for a Chevelle or Lemans, or GTO
With my big cars, it wouldn’t be a question. Nothing like this is reproduced.
Wishing you good luck.
Chris
Old Oct 30, 2023 | 06:30 PM
tkcutlass's Avatar
This might be what you're looking for
https://autobodyspecialt.com/1968-72...-base-channel/
Old Oct 30, 2023 | 07:29 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Open it up to reveal the extent before ordering parts. You may need more... lots more.
Pull the fenders. Look at the firewall to frame mounts.
Can you weld with a mig or tig?
Old Oct 30, 2023 | 10:32 PM
X2
That kind of rot (or any for that matter) can have very deep damage. Do your homework. If you want to fix it. Plan on fixing it right.
Old Oct 30, 2023 | 11:10 PM
cfair's Avatar
We're completely spoiled here in CA for rust, but both of my '66's have just a little. hiding on the lower edges of various panels.
In my 98, it's on the cowl buried underneath the driver's side fender at the rear. No other problems since this car has been garaged its whole life. First by my Dad, then by me. It see mostly Summer use and maybe 3-5 days/year of rain.
In my Starfire coupe, it had the typical bottom of the rear window rust which got fixed in 1997, but has returned in the most minor way 25 years later. About a year back I had the lower driver's quarter cut out and replaced for a dime sized bubble. I'm in no hurry to a 1/2" size hole on the passenger quarter.
So I'm ignorant, but I can say, if you're going to fix it, fix it right or it'll come back some time.
Chris
Old Oct 31, 2023 | 02:59 AM
Good that the cowl is at least available.
Old Oct 31, 2023 | 05:37 AM
gear head's Avatar
I had the same issue with my car, you may want to source it from a doner car. I don't think that repop panel will give you enough material. As previously stated, there is a high probability that there is much more to fix once it's removed.
Old Oct 31, 2023 | 03:05 PM
marxjunk's Avatar
We are oprning it this week end..its a colorado car i bought on this board..perfect trunk..had rubber floor mats so floor pans are gone..its a no option 70 F85 post car
Old Oct 31, 2023 | 03:07 PM
marxjunk's Avatar
Is 68 69 dash piece the same..i have a 68 and its terrible..but rust free in the dash area
Old Oct 31, 2023 | 07:41 PM
truckman5000's Avatar
W30
I'm not sure on the above panel..I havent seen it but it said slides over.
The only way is to clean weld bonds
to my knowledge
Old Nov 4, 2023 | 04:29 AM
newmexguy's Avatar
azchevs
Look up "azchevs" he might have something. Sierra Vista, AZ.
Old Nov 4, 2023 | 10:53 AM
2blu442's Avatar
The 1968-72 windshields are the same shape and will interchange as long as you go 2 door to 2 door. If you have a nice piece in your parts car it would be worth measuring the vent ducts in relation to the glass. I've got a 1970 post parts car but suspect that area in mine is also rotten. John
omy442
25
Mar 14, 2024 06:49 PM
BHM442
Jul 1, 2023 03:18 PM
over my head
Jul 20, 2021 02:51 PM
Adam Michael
Apr 30, 2021 08:30 AM
70sdream
May 9, 2016 04:16 PM
