My notes indicate you will need a KF water pump pulley. KK pulley is a 70 pulley and is designed to be used with the 5.5" 70 waterpump. The 70 5.5" water pump uses different size radiator hoses than the 71/72 5.5" water pump. Looks like you have the 6" pump which is correct for your application. I did not verify the part number. The crankshaft and power steering pulleys you listed are correct. Hope this helps.
Looks like you have the correct information. I was going from notes that I had on my phone. Sorry for the bad info.
Don W
What I don't know is which replacement water pump to buy for these pulleys? Summit Racing has the Milodon one:
Brand:Milodon
Manufacturer's Part Number:16285
Part Type:Water Pumps, Mechanical
Product Line:Milodon Mechanical Water Pumps
Summit Racing Part Number:MIL-16285
UPC: 806621162857
Pump Flow: High-volume
Pump Material: Aluminum
Pump Finish: Natural
Water Pump Rotation: Clockwise
Pilot Diameter (in): 0.625 in.
Water Pump Inlet Diameter (in): 1.875 in.
Quantity: Sold individually.
Notes: 6.000 in. water pump length. The dimensions in the image do not account for any gaskets or the backing plate.
gbledoe3:
I used a FlowKooler pump #1775 on my 375cid small block build. It is all aluminum construction like the Milodon pump with a 6" hub height, and my pulleys all line up perfectly. Summit has them for $116 with free shipping. Here's a link: https://www.flowkoolerwaterpumps.com...duct_info.html
