Correct paint.
Old Aug 29, 2009 | 07:29 AM
nukesec1's Avatar
Correct paint.
Can anyone tell me where I can get the correct black paint so I can refurb my air cleaner? I do believe the same color was used on frames and anything else that was black under the hood. I want to be as correct as I can be here. We've all seen restored cars at shows that have that "over restored" look to them. I'm trying to stay away from that.
Old Aug 29, 2009 | 02:58 PM
Dan Wirth's Avatar
I've used Rustoleum paint on my air cleaner. It was gloss black and I'm sure it looks better than the original (which I know is not the desired effect you're looking for). I think that a satin finish, should bring it closer to the original and I may make the change...
Old Aug 30, 2009 | 06:09 AM
wolfman98's Avatar
Captain of my ship
You may want to try a semi-gloss paint if you don't want it too shiny or too flat. Satin will work too.
Old Aug 31, 2009 | 07:02 AM
I've heard semi-gloss black from your local auto parts store is the best way to go. I've used it on engine brackets and it is "close" to the original. You might check out Fusicks, they probably have an over-priced can of spray paint in semi-gloss black that you could buy if you "must" be "original."
Oct 24, 2008 02:08 PM
toplessrocket
Apr 20, 2008 07:11 AM
desert442
Apr 18, 2008 11:24 PM
Tamiob
Aug 1, 2007 10:34 AM
woody
Dec 30, 2006 07:40 PM
