Correct fan paint color?
Old Mar 28, 2025 | 03:52 AM
72455's Avatar
1972 U code Supreme
I figured since I was replacing the fan clutch on my '72 Supreme, I may as well clean and paint my fan while I'm at it. Does anyone know the correct paint color for the fan?
Old Mar 28, 2025 | 04:54 AM
black
Old Mar 28, 2025 | 05:12 AM
72455's Avatar
1972 U code Supreme
black
Just any black?
Old Mar 28, 2025 | 05:21 AM
jaunty75's Avatar
Yes, black.
However, when I replaced the fan clutch on my '78 Toronado a few years ago, I decided to paint the fan blue just for the H of it. The fan was fine mechanically but looked awful, and I had some blue spray paint laying around, so I thought what the heck. The fan is largely hidden under the shroud, so no one ever sees it, even at car shows.
Here's the fan as it came out of the car with the clutch still attached.
Here's the fan reinstalled with the new clutch and painted blue. The purpose of the repair was to replace the water pump, but since I had to take everything out, anyway, I went ahead and replaced the clutch and cleaned and repainted the fan.
No, it's not the correct color. It's my little secret.
Old Mar 28, 2025 | 08:39 AM
Just Google "GM Reconditioning Black".
Close enough.
Old Mar 28, 2025 | 08:41 AM
jaunty75's Avatar
Better yet, just go to the hardware store and buy some black spray paint.
Old Mar 28, 2025 | 08:48 AM
He wants it to be correct.
Old Mar 28, 2025 | 08:55 AM
69HO43's Avatar
Low gloss black. It appears to be the same color as the pulleys. I could be wrong, though. But if you redid the pulleys and fan the same color and gloss level, it'll blend and nobody will notice. I know for sure it's not flat black or gloss black.
Old Mar 28, 2025 | 09:12 AM
72455's Avatar
1972 U code Supreme
I have semi gloss in the garage, so I'll go with that.
Old Mar 28, 2025 | 09:21 AM
Make sure you post after pics.
Old Mar 28, 2025 | 09:28 AM
72455's Avatar
1972 U code Supreme
Of course
Old Mar 28, 2025 | 06:14 PM
Charlie Jones's Avatar
Phantom Phixer
[QUOTE=72455;1622589]I have semi gloss in the garage, so I'll go with that. [/QUOTE
BINGO.
Old Mar 29, 2025 | 03:52 AM
Bfg's Avatar
Bfg
I would go with a light shade of black
Old Mar 29, 2025 | 04:52 AM
Rallye469's Avatar
Here’s a decent reference for the sheen on an engine of that era
Old Mar 29, 2025 | 08:33 AM
F-85 4-4-2's Avatar
Who cares about the engine, look at that hair! Now that, that is a woman!
I used PPG DCC9348 single-stage "semi-gloss" black on my underhood components. Same sheen as GM Reconditioning Black, 40-60 Gloss, but the DCC uses a hardener, so it's much more durable.
Unfortunately, PPG single-stage has gone the way of lacquer, they no longer produce. AkzoNobel, Eastwood, Summit sell, but you'll drop $80 for a quart+hardener.
For just a fan, go your semi-gloss rattle can.
Old Mar 29, 2025 | 05:09 PM
Originally Posted by F-85 4-4-2
look at that hair!
That's funny. I thought exact same thing. She has it piled high.
Old Mar 30, 2025 | 10:24 AM
Phantom Phixer
That's a Marge Simpson hairdo.
Old Mar 30, 2025 | 11:00 AM
Yeah, and if she leans forward into that power and free conveyor chain, she is screwed. I mean, holy ***** that would not fly today. Also, it's not good for assembly. Today, engines are usually built on pedestals for more support when you bolt something onto them so they don't swing. I do know my OEM has one line like that at our alliance plant, I'll look at it closer next time. I've done time on engine lines, though I don't any more.
On topic, my rule of thumb is everything is satin, also semi gloss. There is no gloss anything other than body paint and wheel paint. There is also damn little flat. A lot of bolts got black oxided and you could use flat black there.
The problem is there are about 20 kinds of satin black. The good news is it doesn't have to match anything, just be close. Give it a few coats. More coats, less heavy coats, is the way. Sand well and wipe with alcohol first. Maybe prime it.
Old Mar 30, 2025 | 12:06 PM
F-85 4-4-2's Avatar
Heater-A/C boxes, those are gloss, yes?
Old Apr 3, 2025 | 10:23 AM
72455's Avatar
1972 U code Supreme
Before and after pics..
Before
After
Old Apr 3, 2025 | 11:03 AM
Bfg's Avatar
Bfg
I see a run
Old Apr 3, 2025 | 11:16 AM
Originally Posted by Bfg
I see a run
...and, spider webs...
Old Apr 3, 2025 | 11:18 AM
72455's Avatar
1972 U code Supreme
I see a run
Probably...but I'm ok with it.
Old Apr 3, 2025 | 11:20 AM
72455's Avatar
1972 U code Supreme
I know...not quite sure how that happened. Maybe I didn't let the alcohol dry completely? Either way, it's not something I think will be noticeable on the car
Old Apr 3, 2025 | 11:23 AM
Originally Posted by 72455
...it's not something I think will be noticeable on the car
Ya think? Now you can get some sleep.
Old Apr 3, 2025 | 11:29 AM
jaunty75's Avatar
Looks good enough to eat. Your car will probably run cooler now than it ever has. I would have painted it yellow.
Old Apr 3, 2025 | 11:40 AM
Better do it again. You shouldn't settle for anything less than perfection.
Old Apr 3, 2025 | 11:42 AM
I think Dave had plans to outline his undercarriage w/ yellow LEDs.
Old Apr 3, 2025 | 12:38 PM
72455's Avatar
1972 U code Supreme
Norm, if I ever decide to do that, call the authorities , because I'll have definitely gone off the deep end...lol.
Old Apr 3, 2025 | 06:07 PM
Norm, if I ever decide to do that, call the authorities ...
Count on it, Dave.
Tancuda
Jun 29, 2024 09:06 AM
72GoldOlds350
Apr 25, 2020 12:59 AM
ben442
Aug 4, 2016 10:23 AM
goldie442
Aug 9, 2014 08:11 AM
jdana24
Mar 22, 2012 09:26 PM
