Correct Battery???
Old Feb 6, 2025 | 03:33 AM
Cfos0031!'s Avatar
Correct Battery???
Would have a 1969 442 came with a R59 battery when new? If not, does anyone know what it would have been? Thanks everyone!
Old Feb 6, 2025 | 04:53 AM
zl1 camaro's Avatar
I am fairly certain this would of had a 24 series top post battery. I believe the R59 is the one.. Side post were out in 1971
Old Feb 6, 2025 | 05:49 AM
VC455's Avatar
Barely Registered
I did extensive research on batteries to write a two-part article for Journey With Olds magazine in 2022. I realize you have a 442, but here is the fitment information for top-terminal Energizers throughout the entire Cutlass lineup...
· Models from later 1966 through 1971 with I-6 engines used the Y-55 battery (9½ x 6.81 x 9½” tall), rated at 2350 watts and 275 CCA
· Later 1966 through 1971 models with 330 and 350 V8s but without the HD battery or the HD starting motor used the R-59 battery, rated at 2900 watts and 335 CCA.
· From later 1966 through 1969, models with 400 V8s, or with the HD battery or the HD starting motor, used the R-69 battery (same footprint as R-59 but ¾” taller) rated at 3150 watts and 380 CCA. (The 1966 W30 used the R-69 battery.)
· 1968 and 1969 Hurst/Olds used the more powerful R-71S battery (1¾” longer than the R59).
· 1970 Olds 455s, or those with option T60 (HD battery), used the R-71S battery.
· 1971 Olds 455s or those with the HD battery used the R-7 1.
Old Feb 6, 2025 | 09:13 AM
Cfos0031!'s Avatar
Thank you very much!!!!
Old Feb 6, 2025 | 02:34 PM
Tri-Carb's Avatar
Here is the source for the R-69 battery decal. I do not think the battery is reproduced. You can use a R-59 topper and overlay the R-69 sticker.
Battery Top (R-69 Decal) – StageWonRestoration.com & DieCastMuscleCars.com
Old Feb 6, 2025 | 06:39 PM
Cfos0031!'s Avatar
I ordered it today. Thanks
Old Feb 6, 2025 | 07:54 PM
Hairy Olds's Avatar
Shoveling Snow
In all my years of owning factory installed batteries and service replacement batteries I have never seen this decal on any of these batteries.
orlandod
Nov 6, 2024 11:27 AM
maddoctor
Oct 24, 2024 04:39 AM
ericisback
Sep 26, 2023 03:54 PM
Jon442
May 10, 2021 07:31 AM
Neil Morrison
Feb 28, 2020 06:35 PM
