Convertible Top Cylinder - How to Access
Old Jun 24, 2014 | 01:39 PM
kens69olds's Avatar
Hi, newbie convertible guy here. I have a '69 Cutlass and it appears the convertible top cylinder or line is leaking near the driver's rear tire. I know, in general, where it is located but does anyone have a suggestion on how to access it to inspect?
Old Jun 24, 2014 | 03:20 PM
Tedd Thompson's Avatar
Welcome aboard, First of all I know little about 69 verts but if it were an older car the pump cylinders and motor should be hiding behind the top boot(some call it a bag). Mine is accessible either by unsnapping the bag from from the mounting frame behind the back seat or come at it from the trunk. Either way you can't miss it. If this is wrong its because I haven't kept up on these new fangled cars but this should get you close....Tedd
Old Jun 24, 2014 | 03:37 PM
On this era car the cylinders are behind the vertical panels at the rear of the arm rests.
The arm rests and rear panel come out together as an assembly. Remove the rear seat first, then remove the arm rests and cylinder covers.
Here's an old pic I found of my car with the top cylinders showing:
Old Jun 25, 2014 | 07:35 AM
kens69olds's Avatar
Thanks a ton you guys! Pics are super helpful. Appreciate it.
john116
Dec 20, 2013 03:22 PM
costpenn
Oct 27, 2012 07:07 PM
dougm
Aug 15, 2011 05:05 AM
KevinBN7
Jul 17, 2011 01:02 PM
67442nut
Oct 12, 2010 08:00 AM
