Clutch Master Cylinder Firewall Bracket
Old June 29th, 2011 | 11:34 PM
Jocko124's Avatar
I'm installing a 6 speed in my 66 Cutlass and need a bracket to mount the clutch master cylinder. Does anyone know where I can get one or have any of you made one or modified a bracket from another application? Any help would be appreciated.
Old July 1st, 2011 | 08:10 AM
Jocko124's Avatar
B u m p
Old July 1st, 2011 | 08:54 AM
gearheads78's Avatar
car guy
Lee you might look into what the 64-67 Chevelle guys are doing. I would just make it from scratch from 3/16" plate if it was mine.
Old July 1st, 2011 | 08:56 AM
Jocko124's Avatar
that's the current plan, but I wanted to double check b4 reinventing the wheel. You made yours from scratch? I've been too lazy to go look through your build thread!
Old July 1st, 2011 | 09:05 AM
car guy
I just converted to factory mechanical linkage when I did my 5-speed swap. I wanted to do hydraulic but it was out of my budget.
Old July 1st, 2011 | 09:07 AM
Jocko124's Avatar
Thank you Sir.
Old July 2nd, 2011 | 02:59 PM
Bill in NC's Avatar
I'm not sure what the Chevelle guys are using, but could you use a factory 3rd gen F-Body master reservoir/bracket? They mount to a bracket that bolts to the master cylinder stud.
Old July 3rd, 2011 | 12:03 AM
Jocko124's Avatar
Thanks Bill, I'll look into it.
Old July 3rd, 2011 | 05:26 AM
scr8p's Avatar
why don't you get a reservoir with mounting tabs molded in?
Delmont 88 PA
April 26th, 2015 06:28 PM
Delmont 88 PA
April 14th, 2015 06:05 PM
47 Convertible
April 3rd, 2014 08:56 AM
RandyS
March 8th, 2014 06:07 AM
