Club Coupe is almost done
Car is real close to completion. Glass is back ordered and front end sheet metal needs aligned. Other than some small things its close to being on the road. I actually drove it last week around the block. Plan is to have it at the 2020 OCAs
Thanks Joe. I just read the build thread on Freds 79 F100. Unbelievable attention to detail. Has to be the nicest 79 F Series restoration Ive ever seen. I had a 79 F150 Custom 4x4 short bed. 300 I-6 and a 4 speed, drove it daily while I spent money on restoring my first 65.
Great job on a Great 65. I was wondering if you used the same material for the seats on the dash pad? My 65 442 uses the red metallic vinyl on the seats , but the dash pad is faded and I can't tell if it was metallic at one time?
Thanks, Steve
Thanks, Steve
I guess mine is plastic too, with what feels like a layer of foam beneath it. I will use the material I got from you and recover it in the metallic red. I had my upholsterer cover the last on and it came out very nice. Here are a couple of photos from my 64 that was redone and the original 65 dash . Might just paint the 65 for now Parts Place offers color matched PUI paint. They have a metallic red available.
#36
#37
Ive added a few things since the car was unofficially finished. The original washer feed hose had a yellow stripe on it. The reproduction coolant tag that is sold for 65s is not correct. Found the correct tag and clipped it in place. Hoses now have the correct blue stripes and codes. Also added a Delco distributor cap and hooked up the vac line to the flapper valve attached to the air cleaner. I totally forgot to run that hose since my other car was built at Fremont and doesn't use the flapper valve. Bought fuel feed line with SWAN gas logos. Installed an NOS horn relay I found on eBay. Horns blast so the problem is in the steering wheel. Lastly I decided to use the water valve that only was used on 65 442. Its a very rare part that guys tossed out when they failed.
#39
Amazing...sheer beauty
The car looks amazing Jasen, gives me motivation to work on mine. That SMS fabric looks high quality. I still need to order mine...the wallet just needs some WD40 to open that wide.
As always, fantastic work.
Christophe2m6
January 7th, 2016 04:05 AM
