Clear coat Anodized parts?
Hey guys, just looking for a few rattle can suggestions for putting a clear coat on some new parts.
What brands do you like best?
New Booster and MC coming in this week and want to help it look a little better for a little longer.
Not show car or anything.
Thanks!
-peter
Thanks!
-peter
Just don’t get any brake fluid on that clear, it will stain/wash right off. Only catalyzed clear/paints have a decent chance of standing up to brake fluid and even then it’s no sure bet.
Rattle can is just minimal solids in a solvent, when the solvent evaporates it leaves behind the solids. Catalyzed clear, the higher the quality the more solids and UV protection it contains. It has very minimal solvent and when activated it chemically hardens by cross linking the solids creating a very durable paint, any solvent is there just to allow it to be sprayed.
Clear coating those surfaces is a good idea, just be aware of solvent sensitivity.
ECS makes a product that is supposed to help protect plated parts and keep them looking nice:
https://ecs-automotive-concepts.mysh...gic-guard-4-oz
I have some but haven't used it, their RPM (rust prevention magic) has worked pretty well from my experience.
Just to clarify, nothing in that photo is anodized. Anodizing is an oxide layer on aluminum. The RPO B85 trim parts are anodized, for example.
The gold coating on steel parts is alodine. That brake combo valve is brass and that's just the natural color.
The problem with clear coat paint is that you can't sand the surface to promote adhesion. I've had bad experiences with clear coat peeling from smooth surfaces.
I've been using Sharkhide on polished aluminum and alodine steel. So far so good.
Also, consider the Eastwoom master cylinder paint for the cast iron M/C. It's pretty much brake fluid resistant.
"alodine" ...that's very interesting, never heard that before.
I guess I knew it wasn't really anodized...but didn't know that term.
Thanks!
And yeah...that eastwood paint is great.
-peter
Thanks!
-peter
Well, alodine is apparently a brand name (owned by Henkel, who also makes Loctite) for chromate conversion coating. I didn't know that until just now. We always called it by the brand name when I was at Hughes.
From Wiki (yeah, we all know how accurate THAT is... ):
Chromate conversion coating or alodine coating is a type of conversion coating used to passivate steel, aluminium, zinc, cadmium, copper, silver, titanium, magnesium, and tin alloys.[1].1265[2] The coating serves as a corrosion inhibitor, as a primer to improve the adherence of paints and adhesives,[2] as a decorative finish, or to preserve electrical conductivity. It also provides some resistance to abrasion and light chemical attack (e. g. from dirty fingers) on soft metals.[2]
Chromate conversion coatings are commonly applied to everyday items such as screws, hardware and tools. They usually impart a distinctively iridescent, greenish-yellow color to otherwise white or gray metals. The coating has a complex composition including chromium salts, and a complex structure.[2]
The process is sometimes called alodine coating, a term used specifically[2] in reference to the trademarked Alodine process of Henkel Surface Technologies.[3]
Yes, that's where I used it, but it's a chromate conversion coating that's also used on steel, zinc, and other metals.
Wiki makes it sound like "3 in 1" oil. "We" (major airline Overhaul Base) had chemical tanks and procedures that were standardized to satisfy Boeing, Douglas, McDonnel-Douglas, Airbus and probably Convair. I think the protective coating was dictated by where the part would reside. The "plating department" had tanks dedicated for individual processes. Passivating, Alodine, Unbrite-Cad, Chrome (Industrial), Copper, and perhaps others. Some processes/steels required ovens to bake parts the reduce the risk of "hydrogen-embrittlement". Some parts being repaired were cleaned mechanically (blasting with various materials) or electro-chemical process (such as chrome removal).
Yes I understand. You zinc plate steel parts and for the ones who don't know,the silver zinc is called clear and the yellow/gold is simply yellow zinc. Then you have black oxides &, phosphates.. These are the most common coverings used on these cars. Cadmium was used on a lot of OEM parts but is hard to get done,so clear zinc is most used to duplicate cadmium.
Good luck with that Sharkhide. I stripped, then polished, the aluminum wheels on my Silverado. It lasted exactly 3 drives in the snow/salt. They need to be taken all the way down with 80 grit again. As a comparison, I used Duplicolor Wheel Clear on the back, and they're still good a year and a half later.
ThyPlumber
April 27th, 2009 12:55 AM
