CLANK! Random parts fell out of 64 Jetstar
Old April 9th, 2019, 05:47 AM
foulpalamont's Avatar
Like a scene out of the movies, I’m leaving parts behind on the street. I was pulling out of my driveway today when I heard a KLANK!, and found the two parts or parts of parts on the road any ideas? I was turning the steering wheel when the long cylinder fell off. The hose piece was found where I had been parked.
foulpalamont is offline
Old April 9th, 2019, 05:58 AM
That is a rubber bushing. Check your control arms and shocks.
oldcutlass is offline
Old April 9th, 2019, 06:09 AM
Thanks! Are both of those parts associated with the control arms and shocks?
Old April 9th, 2019, 06:19 AM
Nix the shocks, If a control arm looks like this:
Old April 9th, 2019, 08:57 AM
2blu442's Avatar
Here's where it would be if its a front A arm bushing, this picture is from a 1966 Cutlass A arm so yours might be a little different shaped, but still have two bushings where the A arm connects to the frame crossmember. There should be a bolt through the center of that bushing and it would be unsafe to drive the car with one of these missing. It could also be from the rear. Does the size of the items look similar to these?
2blu442 is offline
Old April 9th, 2019, 09:10 AM
2blu442's Avatar
If the front bushings are all there then it might be from the rear end. I'm not well versed in the 1964 Jetstar, but think you'd still have the same bushings as this rear end from a 1964 Cutlass. There's two on top of the pumpkin, with short arms that have bushing attached to the frame above the rear end. Then the lower control arms have bushings on each end, attaching the rear end to the frame in front of it. All these should have bolts running through the middle of them so that's the thing to look for, a missing bolt. Let us know if this resolves your question. John
2blu442 is offline
Old April 9th, 2019, 09:20 AM
Don R.'s Avatar
That's pretty serious, don't drive your car until you identify the problem.
Don R. is offline
Old April 9th, 2019, 09:48 AM
Thanks gents. will let you know as soon as I do. This gives me a good place to start. I was able to drive the car about half way down the block without issue, but I'll keep it there until the mystery is solved.
Old April 9th, 2019, 01:08 PM
The serrations on the end of the metal tube lead me to think that is an upper control arm bushing.
Wherever it came from, I dunno how the sleeve could fall out unless the bolt / nut was missing as well.
Fun71 is offline
Old April 9th, 2019, 03:33 PM
72 Olds CS
RetroRanger's Avatar
x2
RetroRanger is offline
Old April 9th, 2019, 03:35 PM
MOTORHEAD
11971four4two's Avatar
Klink Clank Klunk
11971four4two is online now
Old April 11th, 2019, 04:39 AM
Here's my guess, new parts were installed in the past- maybe years ago. The old control arm or rear end bushing/sleeve was hammered out and ended up under the car, new parts were installed, car drove away with old parts stuck up in a cavity and finally fell out then....??? As others have said those pieces look like would be held in with a bolt and if the bolt and those parts came out I think you would know it now! I have found lots of old parts/tools under cars. I found a set of channel locks under the old truck I just bought. All rusty and seized up like they had been there a year or more. I would check the car for sure and make sure though..
Greg Rogers is offline
Old April 11th, 2019, 06:02 AM
Greg has a point. My lawnmower came to me occasionally having only 50% of the right steering, and a swiss army style torx key wrenches tool was laying there blocking it.
Koda is offline
friesjh
October 12th, 2017 05:48 AM
Bee-Oh-Pee
April 25th, 2016 08:31 AM
jetstar88mike
May 26th, 2015 02:19 PM
Jetstar 88
March 20th, 2011 11:26 AM
therobski
October 24th, 2009 01:54 PM
Quick Reply: CLANK! Random parts fell out of 64 Jetstar
