Chucks
Old Jul 23, 2020 | 07:36 PM
OldsmobileLiam's Avatar
Chucks
I found something quite a concerning today when I was working on my 64’ Oldsmobile 98 town sedan. I had opened up both valve covers and noticed that there were large metal fragments. I Dont know what of but nothing appears to be damaged. Any insight helps.
Old Jul 23, 2020 | 08:11 PM
You sure they are metal, look like valve guide seals to me.
Old Jul 23, 2020 | 09:01 PM
rocketraider's Avatar
Oldsdruid
I think so too. Common 394 failure. Without them you might notice higher oil consumption but if you're reasonably mechanically inclined replacing them on the car is no biggie. You'll need a special spark plug hole air fitting and an air compressor. Shop book will detail removing the rocker arm shafts, valve springs and keepers with compressed air holding the valves closed.
Daresay finding the seals and new valve keepers (if needed) will be hardest part of the job.
Old Jul 23, 2020 | 09:04 PM
Oldsdruid
Use a bright light and look between the valve stems and valve springs. You'll probably see more of these pieces in there around the stems.
Old Jul 24, 2020 | 10:27 AM
Thank you all for you input no I can understand what I need to do next.
brandon reynolds
Feb 17, 2021 12:25 PM
BeenThere
Feb 17, 2021 04:18 AM
dcmike783
May 11, 2020 09:33 PM
Olds luvr
May 12, 2010 01:24 PM
