Choke cable question
Old May 17, 2025 | 05:35 AM
79cut's Avatar
My 79 cutlass does not have a choke when I bought it
I bought one off amazon and ran the cable etc.
the cable seemed very thin and it would close the carb flaps fine but didn’t have the power to open them fully
I have a Holley double pumper
my question is the choke quality
Are there chokes with good strong cables vs others. ?
Old May 17, 2025 | 05:53 AM
Now that is out of my system. 😁
I would think you could adjust the cable or bend the linkage in some way so the choke fully closes, and opens without binding.
Old May 17, 2025 | 06:11 AM
79cut's Avatar
oh oh. Is there carb battles here lol
didn’t know
Old May 17, 2025 | 06:55 AM
The cable sleeve needs to be anchored securely at the carb and the dash and routed without sharp bends in the cable.
Old May 17, 2025 | 07:40 PM
79cut's Avatar
That is what I did. But wondering if you know of any choke cable that are stronger than others
Old May 17, 2025 | 08:07 PM
I've never really studied choke cables, I have used the Holley one. I guess you could look at wire diameters.
Old Jul 12, 2025 | 05:41 AM
79cut's Avatar
Bringing this back for update
after trying the dorman choke cable that didn’t work good as it was to thin to push the flaps open
I bought the Holley cable and yes.
it’s a much thicker cable
no more issues
Old Jul 12, 2025 | 05:45 AM
no more issues
I have a non-GM car with a manual choke 2 barrel Autolite. I put a Holley choke cable on it with a Holley carb. The carb was replaced with the Autolite, but the cable remained. It has done ok, but I have had to lube it recently, so I think I will replace it with another one I have here. I do not have opinions on Holley chokes themselves. I do think Autolites are real bitchy until they warm up.
Old Jul 12, 2025 | 05:47 AM
79cut's Avatar
well the Dorman cable I got was way to thin
Old Jul 12, 2025 | 08:17 AM
It should take virtually zero force to open the choke. Start by disconnecting the cable from the carb linkage and see if it takes any effort to move the linkage by hand. If it does, fix that. If it doesn't, see if you can move the cable by itself. If not, it's binding and either you need to fix the bind spot or get a new cable. There should be no need for a "heavy duty" choke cable, which is why you won't find one. Find and fix the real problem.
Old Jul 12, 2025 | 08:56 AM
79cut's Avatar
not sure if the Holley is considered the heavy duty cable but it’s doing the job just fine now
Old Jul 12, 2025 | 11:53 AM
I think the heavy duty idea comes from the cable sheathing. The one on my van now is wraparound metal, like it's in a spring. The one I have for it is plastic and coated. Perhaps it will retain more lube.
Yes, a correctly working choke cable should take the minimum of drag to pull upon.
Old Jul 12, 2025 | 02:54 PM
79cut's Avatar
the sheathing looks the same on both cables
the Holley cable inside the sheathing is noticeable thicker which is what I needed
the Dorman cable is very thin and weak
79cut
Dec 27, 2024 04:06 AM
Kapos79kutlass
Jun 3, 2024 04:46 PM
Moegs
Jun 7, 2023 09:01 PM
74 fastback
Oct 13, 2015 09:27 AM
ralsy
May 31, 2012 06:21 AM
