Checking Compression - 1970 442
Old Jan 31, 2025 | 01:00 PM
WTHIRTY1's Avatar
Escape From The Ordinary
When checking the compression on all 8 cylinders, is it best to remove all the spark plugs or one at a time when testing?
Is it better to just remove the coil wire or also the hose going in to the fuel pump as well?
Picked up a remote starter and looking forward to trying it but not sure if I'll have any issues using it on a stick car.
Old Jan 31, 2025 | 01:05 PM
It’s best to remove all the plugs, the engine cranks faster, and the battery will last longer.
Definitely disable the ignition, and obviously make sure the trans isn’t in gear and the wheels are chocked. Using a remote starter switch will bypass the clutch/neutral safety switch.
Old Jan 31, 2025 | 01:21 PM
WTHIRTY1's Avatar
Thanks, Matt.
Old Jan 31, 2025 | 02:27 PM
Sugar Bear's Avatar
X2 to the above and no to the question about disconnecting any fuel lines. If you really felt it necessary you could pinch the rubber supply hose to the fuel pump.
Old Jan 31, 2025 | 02:47 PM
Red face
I usually charge up the battery and do one at a time because I'm just addle-minded enough to get the wires mixed up if I take them all off at once. If I have to do two sessions one bank each, oh well.
EDIT: If you do decide to take them all off at once, make sure you label them, and mark the corresponding spot on the distributor. The numbers on the intake should tell you what you need to know there ...
Old Jan 31, 2025 | 04:10 PM
It's also a good idea to have another vehicle handy so you can put a set of jumper cables on your Oldsmobile.
teqdave
Nov 21, 2013 03:29 PM
66cutlass
May 12, 2013 01:28 PM
defiant1
May 20, 2011 09:56 PM
Daniel2008
Jan 1, 2009 07:43 PM
1973_442
Jun 13, 2007 09:22 AM
