Chances of finding a second build sheet?
Old Sep 30, 2024 | 11:40 AM
72455's Avatar
1972 U code Supreme
I've already found one tucked up under the driver side bucket seat for my Fremont built '72 Supreme, but what's the likelihood of there being a second one above the gas tank?
Old Sep 30, 2024 | 12:37 PM
70W-32's Avatar
Pull it down a little and shine a flashlight across the top of the tank. You dont have to remove it unless you find one.
There being one is all dependant on who was installing gas tanks the day your car was built
Old Sep 30, 2024 | 03:00 PM
72455's Avatar
1972 U code Supreme
Would it be easy to see or underneath the padding?
Old Sep 30, 2024 | 03:15 PM
cdrod's Avatar
Rodney
I had an Arlington-built 71 Cutlass Supreme back in the late 1980s; found one under the rear package tray when I repainted the car, also found one in the drivers bucket seat back when I recovered the seats.
Old Sep 30, 2024 | 04:19 PM
70W-32's Avatar
I dont know Fremonts build process, so all I can suggest is you drive the car till its empty,
loosen the 2 bolts that hold the straps, lower it a bit and look.
While your there, inspect the condition of your fuel and evap hoses, and replace as necessary
Old Sep 30, 2024 | 04:38 PM
Rallye469's Avatar
Purpose for finding a SECOND build sheet?
ya greedy bastard.
Old Sep 30, 2024 | 05:41 PM
72455's Avatar
1972 U code Supreme
ya greedy bastard.
Well, when I found the first one, I made the hasty (and probably not the best) decision to laminate it. It's in really good shape and has held up well being tucked away in my safe. So if I find a second one, I'm going just put in a plastic sleeve and tuck it away with my other one.
holidaysedan
Apr 27, 2026 04:53 PM
Last98
May 31, 2023 10:30 AM
Puppy boy
Apr 5, 2021 10:45 AM
72455
Nov 26, 2020 07:13 PM
Zacc
Feb 15, 2017 04:18 PM
