Is this a case of mis-matched motor mounts?
Old Dec 11, 2021 | 04:38 PM
young olds's Avatar
I bought some 72 frame side mounts( claimed to be out of a 350 car) and used them to replace sbc frame sides. Engine has the same passenger mount that came on it( 403 out of a 78 Buick) and I replaced the drivers side with a small block mount I had( the 403 just came out of my wagon which used the diesel motor mount). Over the years I’ve seen time again the big block vs small block( having to use a matched set) issues but I’ve never ran into it myself. Planning to buy new motor mounts anyways but want to make sure I’m buying the correct ones and I’m not sure my issue is in fact that I need big block engine mounts.
these are the frame sides I purchased.
if it’s not a mis-matched issue, what am I dealing with?
Old Dec 11, 2021 | 05:16 PM
young olds's Avatar
I did do some research before I purchased the frame side mounts.
it’s appears to me I did buy the corrects frame side mounts, car is a 72. This is only the second car I’ve swapped frame sides and had zero issues with my 66 going from 6 cylinder to sbo.
Old Dec 11, 2021 | 05:22 PM
young olds's Avatar
After further research it seems to me my issue could be because I’m using a b-body mount on the passenger side of the block. I’ll swap it tomorrow with another 2261 motor mount and see how I fair.
Old Dec 11, 2021 | 07:02 PM
Every Olds motor built from 1973-1990, including 260s and 307s (and your 403) came from the factory with 2328 motor mounts, which is why I implore people not to call these "big block" mounts. Your 1972 frame pads need 2261 motor mounts.
Old Dec 11, 2021 | 07:24 PM
young olds's Avatar
Thanks for the confirmation, for some reason I was under the impression that all small blocks used the same motor mounts which is why I only swapped the drivers side mount.
Old Dec 11, 2021 | 07:27 PM
Originally Posted by young olds
Thanks for the confirmation, for some reason I was under the impression that all small blocks used the same motor mounts which is why I did not put both of my 2261 mounts on.
And that's why I keep saying we need to STOP calling them "SBO mounts" and "BBO mounts".
joe_padavano
Tech Editor's Desk
110
Jan 1, 2026 08:36 AM
matt506
Tech Editor's Desk
May 28, 2020 08:34 AM
edzolz
Aug 21, 2017 08:44 AM
chrisneu68olds
Feb 15, 2012 10:31 AM
TripDeuces
Jun 10, 2010 08:49 AM
