Carb tuning
Carb tuning
I'm curious if anyone else has tried this or has an opinion on it.
I installed a bung after my header collector and installed a single wire O2 sensor. I ran a wire from it into the cab and attach it to a volt meter. I ground the other volt meter lead and have a makeshift narrow band O2 sensor. My cheep digital multi meter displays volts to the thousandths which seems to work better than my much more expensive "Fluke" meter. Everything I read says these O2 sensors produce from 0 to 1 volt with 0.45 being stoichiometric on gasoline. However, looking at a graph of output voltages/ ratios, anything from 0.5 to 0.9 seems pretty close to me. When I first installed it I was reading a solid 1 volt. I jetted my mains down 2 sizes at a time several times and now see anywhere from 0.750 to 0.980 maybe even bumping into 1 volt occasionally. Idles at a stop light around 0.650. I think I could safely go one or two more sizes down on my mains.
Car runs much better now.
Thoughts?
Thoughts?
A good main jet test is a long fairly steep grade so you're running off the jet and not dipping into the power valve, you may need a vacuum gauge to ensure you don't go below the power valve opening rate. If the car is surging during the test it usually indicates a lean condition. There are YouTube videos on jetting and Holley's website.
