emergency who can read wire schematics
Old Apr 18, 2010 | 10:57 AM
gearheads78's Avatar
car guy
I think I found the problem with my wifes van but the circle loop thing between the a/b wire has me confused. What does that mean?
Old Apr 18, 2010 | 11:23 AM
Lady72nRob71's Avatar
It possibly means the wires are twisted to reduce EMI pickup...
It could indicate a shield, but i do not see it grounded anywhere.
Old Apr 18, 2010 | 11:31 AM
car guy
It is a twisted wire. So nothing to do with the two should be conducting with each other? I have the some ohms A to A as I do A to B.
Long story short I had to put new intake gasket on my wife 99 Silhouhette van and after the nightmare of install last weekend it won't start. No spark. I have taken it back 1/2 way apart and tripple checked conections and its all right. I then started Ohming wires and found this.
Old Apr 18, 2010 | 12:40 PM
I thought it would be a twisted.... No, they are not connected to each other.
You should have some sort of resistance through that pickup coil, but it would be in the milli-ohms - very low and hard to check. It will be hard to tell what the resistance is without a very sensitive meter.
Did you change that sensor or damage it or its wires in any way?
Is the sensor close enough to its triggering device?
Newer cars are a pain to work on...
Old Apr 18, 2010 | 12:48 PM
car guy
problem solved....the crank trigger harnness had been too close the exhaust for a long time. When I had the harness loose I must have disturbed it enough to break the burnt insulation causing a short. Fired right up now.
Old Apr 18, 2010 | 01:15 PM
Great - glad you found the problem. Sounds like duct tape to the rescue!
Old Apr 18, 2010 | 03:48 PM
greenslade's Avatar
It may mean that the wires carry a A/C signal from sensor.
Old Apr 18, 2010 | 04:52 PM
olds425's Avatar
Thanks for posting the solution. Always nice to know it was fixed, and good job!
Old Apr 18, 2010 | 05:11 PM
jensenracing77's Avatar
Originally Posted by greenslade
it may mean that the wires carry a a/c signal from sensor.
x2.
Takid455
Jul 16, 2015 09:16 AM
stanjayne
Oct 24, 2013 11:54 AM
gearheads78
Apr 12, 2012 06:50 PM
CalBear
Apr 20, 2011 10:28 AM
68cutlassdriver
Mar 6, 2011 11:53 AM
