Carb numbers, interchange with other GM lines?
Old August 5th, 2012, 08:21 PM
2blu442's Avatar
OK, I think I know the answer to this question but want to run it by you guys. I've got a 1968 442 4 speed project car. It's been off the road since the early 1980s and everything I've checked has been the correct number except the carb. It's coming up as a Pontiac number, 1968 400 or 428 4 speed application. Since they're both 1968 big blocks and both manual transmissions is there any chance this could have been installed at the factory? I suspect it was swapped on in the early years as the crud buildup on it matches the rest of the engine. But before I sell it and look for an Oldsmobile application replacement I just wanted to make sure there wasn't a chance the factory ran out of Oldsmobile application carbs and stuck this one on there. Anybody heard of that happening? John
2blu442 is offline
Old August 5th, 2012, 09:34 PM
Kickin' It Oldschool
bdub217's Avatar
You guys are lucky to run into all these rare happenings!!! I'm jealous =P I tried finding some info on the web but no luck yet.
bdub217 is offline
Old August 5th, 2012, 10:23 PM
Big Daddy No Bucks
ThePackRat's Avatar
Too bad it wasn't a SD carb.
Ca-ching.
ThePackRat is offline
Old August 8th, 2012, 10:49 AM
Just the facts...
BILL DEMMER's Avatar
no, back in the days you're talking about, the carbs. weren't intechangeable. an olds 350 carb. was calibrated quite differently from any other gm brand. in the mid 70's-80's they did do that as they were sharing powertrains nearly corporation-wide(gm). example: an olds motor in a pontiac, buick, etc. application would have an olds numbered carb.
bill
BILL DEMMER is offline
Old August 8th, 2012, 07:48 PM
Rickman48's Avatar
Maybe it was their 'first attempt' at seeing if it'd work across the board!
Rickman48 is offline
pcard
April 16th, 2014 08:06 AM
Don R
October 6th, 2012 09:47 AM
fasteddi
July 20th, 2011 08:23 AM
alwayssomething
January 29th, 2010 06:52 PM
#1CutlassSupreme
May 14th, 2008 04:28 PM
Quick Reply: Carb numbers, interchange with other GM lines?
