Can't get car into gear
I have had my 72 cutlass, 350/350, automatic, up on ramps for about three weeks. In the last week, I pulled the pan, fixed two stripped pan bolts, put pan back on, and re-filled the transmission with fluid.
I just started it up for the first time in three weeks, ran great, let it warm up for about 5 mins, and it won't go into reverse or drive. I let it run about another 5 mins, and it still won't go into gear.
WOuld the fact that the front wheels have been up on ramps for the last three weeks have anything to do with this? Or maybe I jacked-up the linkage?
Any suggestions? Thanks.
First the basics! How much fluid came out? How much went back in? If it sat for a few weeks, then was drained after a coupe, of weeks, it is very possible that quite a bit of oil drained back from the torque converter. It is very possible that well over 2 quarts drained back from the converter! So if you only put back in three quarts of oil (roughly as the book states) then as soon as you would start the car cold the oil would get pumped back into the converter, leaving the pan dry of oil, or what would be there would be a foamy mess due to cavitation. Start the engine, pull the stick and wipe it. Replace back into the tube. Remove it, and check very carefully both sides of the dipstick. It is very easy to be tricked by 'splash on' the stick. What you want to see is a solid line on both sides of the dipstick near the tip at least. When you check a cold transmission there should be a good 3/4 of an inch solid oil marking on the dipstick. A full warm transmission would of course indicate proper level between the 'ADD' and 'FULL' marks. 'Warm' in general means a good 10 to 15 minutes driving at roughly 70 degrees, or letting the engine idle until the thermostat opens, meaning heat from the engine has at least begun to warm up the transmission. In all honesty it sounds like you may be low on oil, or, like you said, could the rod have been knocked out of the shifter lever on the side of the unit? Check, check, double check! Regards, Howie
I tend to agree.
Keep adding transmission fluid until the fluid is where it should be on the dipstick - it can take a surprising number of quarts to get from the bottom of the stick to the ADD line.
If it's the second, I agree with Vistabrat and Eric. I had that happen a couple of times with low trans fluid. Top it off and you should be good.
If it just won't move the selector lever? You bent something or didn't hook it up right.
Ok, something really basic. When you say it wont go into gear do you mean the transmission selector won't move? Or do you mean the selector will move to RNDSL but the transmission won't engage?
THank you all so much. I would be screwed without you guys. Couple more years and I'll be much better at this stuff!!!!!!!!!!!!!!!!!
I had no idea that the tourque converter could drain as described by VistaBrat. I learn something new from this site every day. Thanks again.
Must have been the torque converter draining. Initially I put 4 quarts in. Based upon the very quick responses to my post above, I added another quart and let it warm up for about 10 more minutes. It then went right into gear. However, this additional quart barely got it up to the "add" line. I didn't have any more tranny fluid. I'll have to go get some more tomorrow and add another 1/2 quart. Bottom line, problem solved.
russell-t
15
Sep 8, 2012 08:21 PM
kevin.horton
Jun 15, 2011 04:05 PM
