Calling for Wisdom: Dash Pad for 68 69
Old May 11, 2013 | 06:13 AM
minertn's Avatar
what is available for dash pad replacement. it seems what i have found is a plastic shell for an overlay of the original. I am in need of an AC pad. your wisdom is appreciated!:confuse d:
Old May 11, 2013 | 08:15 AM
Not much wisdom needed. Good used or expensive recover are your only options. 1969 non-A/C cars with the upper level ventilation used the same pad as the A/C cars, just different vents.
Old May 11, 2013 | 09:23 AM
allyolds68's Avatar
This is your only cheap alternative and I've heard they are slightly better than doing nothing. (I assume this is what you found)
https://www.yearone.com/Product/1964...lass-442/dv68m
Old May 11, 2013 | 11:35 AM
starfire's Avatar
I had mine recovered by Just Dashes. It was expensive, but it looks like new. They recovered my A-pillar pads too. They look perfect.
http://www.justdashes.com/index.html
Old May 11, 2013 | 03:56 PM
I've heard of people filling the cracks with epoxy, sanding and then painting the dash. Plus, my good friend from high school had a Ford Galaxie with a dash pad that was professionally covered in stiched vinyl. It actually looked pretty good.
ajmanning84
Jun 23, 2024 04:34 PM
SmartCarAmerica
Apr 18, 2014 07:28 AM
costpenn
Dec 21, 2012 04:17 PM
Bacchus
Aug 31, 2012 06:45 AM
floater98
May 27, 2010 03:45 AM
