bumper jack
The mast and base are generic to all the GM line of cars. The hook is specific to the year, make, and sometimes the model of the car. Finding the jack is the easy part, finding the correct hook is the difficult part. Starting in 1964 GM was stamping the year and make on the hooks, but I don't know if they continued it into the 1970's.
so if I find the hook, it should fit then. Does it bolt on or snap in? how do you mount to the jack is my Q!
I assume you have a 72 cutlass. Search for a J hook for a 72 cutlass on Google. Have it shipped to your house. It will snap into the jack. When you get it, see it, it will be self explanatory as to how it fits in the jack. You just snap it in. It's easy. Here's one on Ebay. It is the whole shebang though.
http://shop.ebay.com/i.html?_kw=bump...ck&_kw=cutlass
With due respect to Mark Cornea, I borrowed this image from his website Dr. Decal to show the point I'm trying to make
I think you have the wrong jack
I don't think it will - not on a 72 Cutlass. Here's why: The lift doesn't appear to have a grooved reciever for the hook to fit into
compare:
to the OEM jack that my car has and you can see the difference. Don't forget that while some model years and model groups have identical jack lifts, they don't necessarily have the same hooks.
Here's the lift where the hook fits in. Notice the recessed slot (outlined in red) for the hook. I don't see that on the picture that was originally posted; that's why I'm suggesting that it's not the proper lift assembly.
This is the hook for 71/72 (it probably works on 70 also, but not sure)
IMG_1117.jpg?t=1312502459
compare:
