I was messing with a faulty seat belt in my 1980 cutlass that required me to pull the rear seats and trim panels and to my surprise i think i found the build sheet to the car . Have no idea what all these codes are but it's a cool document to have . Anyone care to take a stab at ti?
ah with my glasses now i see she came with the all mighty 260 it had a 307olds in it when i bought it that motor was a little under powered but ran beautifully
Got the cool KM9 aluminum intake! haha Plus the CH2 RPO basically telling you that you got the pancake 4 cylinder A/C compressor.
Note the VD5 and VD6 are your front/rear bumper supports. Front one says it's steel, rear one says aluminum. That's somewhat odd, but not out of place. Most of the time you would find either both steel or both aluminum. Along with your T46 steel hood. I think that was the time they would slide in an RPO T45 aluminum hood every now and again. I remember they were doing that up through 1984, but as to which got which type, it seemed random.
Nothing super spectacular jumps out at me on the options list. They only made 40 zillion Cutlasses back then. But yours seems nicely equipped.
Assuming the seat wasn't swapped instead of the column and engine, I'd guess damage due to theft or accident.
A lot of those tilt columns would loosen up and get floppy at the pivot point and not many people knew how to tighten them back up. I had to learn because of customers coming back saying "it didn't do that before..." Even after I showed them the loose (reverse or E-Torx head) bolts they would not accept the issue was pre-existing. So I did lots of free repairs on them. Some people would just give up and replace with a non-tilt column.
