brake fluid and paint?
i was always told and even read on the bottle of brake fluid that it will eat paint. i goofed up real bad and parked the Rallye 350 under the Jetfire. i have the front end out of the jetfire and brake fluid dripped on the Rallye 350 over the past week. i got it cleaned up this morning but can't see where it hurt anything. i take it that this is not as bad as i was always told or did i just get lucky?
You most likely have new(er) paint on the Rallye? Brake fluid will do quite a job on factory lacquer in short order. Two stage paints with clear coat and single stage enamels must be quite a bit tougher??? Obviously or you’d be real angry right now or it wasn’t brake fluid?
CC does help a LOT. I ended up wiping the BF off the paint with shop towels, but really need to go over it with a hose. Couldn't do that last Nov; the temp was too cold. Wipe down with a wet sponge didn't help - it froze on the metal.
Some rubbing alcohol or wax and grease remover should stay fluid in freezing temperatures. You can rewax when it warms up.
Don't you guys consume all that beer so you're always prepared for these situations??
There's usually a tank of windshield washer fluid under the hood that doesn't freeze and can be used to wash it off if you aren't tall enough for a straight shot or don't have enough pressure to arc over the top of the fender.
Glad to hear it did not damage your paint. Question, if you switch a car to silicone fluid (assuming it does not have ABS) wouldn't that fluid be safe on paint surfaces or will that also potentially cause damage?
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
