Brake bleeder suggestions
Old Sep 25, 2012 | 11:26 PM
Mr Shifty Sidney's Avatar
Has anyone used the MityVac 6835 brake bleeder? I am thinking about buying one and looking for feedback on how good it works and how good it was made.
Thanks,
Don W
Old Sep 26, 2012 | 07:00 AM
442Harv's Avatar
I have one I use it some times, and OK. I have good luck with gravity bleeding also. I have had a line one time, where gravity bleeding, nothing came out, that is where I used the vac pump. The pump is nice to have for othe things also, I think it is a tool every car guy should have.
Old Sep 26, 2012 | 08:00 AM
boese1978's Avatar
I use the 40$, from AutoZone , Mity Vac hand pump, works great, fast and only one person needed.
Old Sep 26, 2012 | 08:50 AM
I have a Vaccula (Vaccula, get it? ) unit that is very similar to the MityVac you showed. It is THE BEST brake bleeding tool I have ever used. One pass at each of the four wheels bleeds the brakes perfectly every time. You don't even need to bench bleed a new M/C - the unit will suck all the air out just fine. I previously had a hand-pump MityVac and I found that the pauses between pumps caused air to be sucked back in at the bleeder screws. The pnuematic bleeders have constant vacuum so that this is not a problem.
Of course, I got my Vaccula for $15 at the Long Beach swap meet years ago because no one knew what it was...
mcox8051
Jun 20, 2015 04:51 PM
WoofWagon
Brakes/Hydraulic Systems
Jan 11, 2012 07:31 AM
Lady72nRob71
16
Oct 3, 2011 07:34 PM
Joffroi
Jan 17, 2011 02:02 PM
Aceshigh
Jun 24, 2010 09:05 AM
