BOP U Joint Question
Old May 28, 2017 | 12:17 PM
67Rocket's Avatar
Do 66-72 BOP A bodies use the same u joint at the rear? If not, what is the difference? Thanks
Old May 28, 2017 | 02:49 PM
techg8's Avatar
I know there is a difference between the 8.2" 10 bolt's ujoint and the larger 8.5" 10 bolt's ujoint.
when changing a rear but keeping a driveshaft, sometimes a conversion ujoint is used that has both sizes. For example when upgrading from an 8.2" rear to an 8.5" rear.
Old May 28, 2017 | 03:52 PM
67Rocket's Avatar
Thanks, where is such a conversion u joint available?
Old May 28, 2017 | 04:05 PM
toymobile's Avatar
NAPA has a good Ujoint with the crossover .
Olds64
Drivetrain/Differentials
May 6, 2017 03:38 AM
1968_Post
Jan 28, 2017 05:41 PM
Torqueline
Jul 26, 2016 01:28 PM
f85mark
Nov 30, 2009 12:13 PM
J-(Chicago)
Aug 22, 2009 09:25 PM
