Booster redo (attempt)
Old May 11, 2023 | 10:44 AM
Carsick's Avatar
I'm re painting my booster. Does the mount to the fire wall get plated of painted?
.Thanks
Old May 11, 2023 | 01:17 PM
VC455's Avatar
Barely Registered
.Thanks
In 1970 the factory plated the booster and its mounting bracket (no paint on either).
I've read about a paint that supposedly replicates the subtle rainbow effect of the original plating, but I've not used it or seen it used.
Old May 11, 2023 | 01:28 PM
GN1220's Avatar
I did this in the late 90's when I converted my Grand National to vacuum. But I didn't buy a kit, just several different colors of spray paint. I think it came out pretty darn good and has held up well for the new owner. This pic is fairly recent.
Old May 11, 2023 | 01:49 PM
Carsick's Avatar
That turned out pretty good!! The one that's on here was sprayed probably a long time ago black. I got it down to bare metal.
Should I wet sand it after primer? Or just start with the base (clear)?
Did you clear it after?
The booster is pretty much attached with 4 big rivets? To the bracket.
Im thinking it was the whole thing in 69. I guess I'll know when i steal a toothbrush out of the bathroom to clean up the bracket🤫
These are the colors in using:
​​​​​​Do you have more pics of the process?
Thanks guys!
Old May 11, 2023 | 01:53 PM
GN1220's Avatar
I'll look for some more pics. I read how to do it in Muscle Car Review a long time ago. Gold base, and random misting with orange and green, believe it or not.
Old May 11, 2023 | 01:57 PM
442Harv's Avatar
I used the one from Eastwood. Looked good when done, but did fade after awhile.
Old May 11, 2023 | 05:57 PM
If you are talking about the cad plating paint kit that Eastwood sells, it is a poor substitute at best. I guess it's better than a rusty booster, but not by much in my opinion. It also requires some artistic ability, since it's really four colors of spray paint that you have to apply in a way that mimics the cad plating sheen. Like the painted woodgrain on 1930s car dashboards, it can look nice if done correctly but frequently isn't.
Old May 14, 2023 | 09:27 AM
Carsick's Avatar
I'm using a flat black enamel primer followed by a gold base, dusted with semi translucent paints then cleared with a 2k clear.
Is it easy enough to take the metal bar/bracket off? Then put it on after the freshly painted m.c cap is on?
heres my colors:
Old May 14, 2023 | 12:57 PM
Magna86's Avatar
Here is what I did with my crusty but good booster.
Old May 14, 2023 | 03:28 PM
Carsick's Avatar
Wow, Magna looks great!
I hope this out half as good!
Old May 14, 2023 | 10:18 PM
Carsick's Avatar
The primer says 7 days before it cures and I can spray the base. Is that necessary?
oldsdriver1218
Brakes/Hydraulic Systems
Feb 9, 2020 04:50 PM
truckman5000
May 17, 2017 06:21 PM
rr480
Mar 12, 2015 09:46 AM
72OldsRocketMan
Apr 18, 2014 03:28 PM
coreyshu
Sep 4, 2008 09:38 AM
