Boneyard Visit - 56 4dr?
Old May 19, 2013 | 10:33 AM
Octania's Avatar
Boneyard Visit Saturday
The '69-70 350 had new lifters and double row timing set, so let's see...
Lug 100 lbs of tools out back. WAY out back. It's good to have a hand truck.
HT starter, better grab that. jack car up, get starter off.
Pull lifters out, yep, they are all new and perfect. Balancer removal... put 1.125 socket on and... it's loose. Previous assembler was an idiot? Pry it a little, to no avail.
OK, get hydraulic puller out.... of the TRUCK?! Dammit 1/4 mile hike... found yard man to watch my tools instead of dragging them both ways AGAIN. Remove motor mount thru bolt, jack up engine, extract damper... meh, there's a generic chinesium timing set. And the lower sprocket does not want to come off. Well, let's see what this hot rod cam is...
Pull the dist'r and then the cam, on the back we have...
"554" inked on? Really? Factory 350-2bbl cam? Dangit.
Weird, the '69 & '70 Assembly manuals suggest that the cam used in the bottom of the line 350-2bbl [with chamfered lower 1/3 or so front face, as I found] would be PN 400085... not xxx554, which I would think that "554" inked on the aft face would mean.
http://wildaboutcarsonline.com/membe...bly_Manual.pdf
So, ended up with some new lifters, one high torque starter, and a core harmonic damper with the stepped OD as used 1968-70 or so.
On the way out I noticed a really old car, 1950's. The cap appears to be on its way in?? Too bad because they never sell cars as a whole at this place.
Body redone-ish, no trim, no front end
I go see... no name, no model
smog era 307 engine?
4dr, would make a great doorless 2-dr.
no body tag. Lots of parts in boxes inside.
open the driver door to find a VIN tag indicating 1956 Olds I believe.
Old May 19, 2013 | 06:44 PM
Partsmart? I saw that car on a car hauler on the way in I think it was that one... I had a friend call about it and they told him they were hauling it/storing it for someone...??
Old May 19, 2013 | 06:49 PM
Octania's Avatar
right, Cat's
I did not inquire about it, had to dash off for Mother's day Luncheon.
I would be happy to hear that Cat's is not parting it- they never sell a whole car.
Old May 19, 2013 | 07:48 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Apparently somebody has clipped it since the motor and everything attached to it is later model.
Octania
Apr 15, 2015 03:35 AM
tattarat
Oct 30, 2011 11:05 AM
Ausraven
Apr 10, 2011 07:14 PM
Jaybird
Apr 21, 2010 10:34 AM
Jaybird
Apr 20, 2010 10:18 PM
