body tag replacements
Old Apr 14, 2014 | 08:56 PM
kjr442's Avatar
Kjr442
I know I have seen a add for body tag replacements, but I cant find anything on it now.
Can any of you help me with this? the body shop that painted my car sand blasted mine, and I am having a hard time reading it now. I'm glad I copied it years ago or this would be real bad.
Old Apr 14, 2014 | 09:28 PM
69oldsguy's Avatar
I believe A.G. Backeast makes the body tags. Here is their website.
http://www.datatags.com
Their quality is top notch. I had them make a replacement vin tag for my Challenger. Cheers.
Old Apr 15, 2014 | 05:39 AM
kjr442's Avatar
Kjr442
[QUOTE=69oldsguy;684485]I believe A.G. Backeast makes the body tags. Here is their website.
Their quality is top notch. I had them make a replacement vin tag for my Challenger. Cheers.[/
QUOTE]
Thank you very much.
Old Apr 15, 2014 | 06:22 AM
66-3X2 442's Avatar
Another option
http://www.trimtags.com/about.html
Old Apr 15, 2014 | 07:06 AM
dfire25's Avatar
"Trying to fix her right"
I'm going to have to go this route as well, my body tag is missing . Does anyone know the code for black bucket seats on a 71 442? Is it 930?
Old Apr 15, 2014 | 07:15 AM
1970cs's Avatar
Lansing built
Yes, 930 is correct for a hard top.
970 for a drop top.
Pat
Old Apr 15, 2014 | 07:21 AM
the good part is you have the original cowl tag info. Where it gets dicey is when cowl tags are replaced containing info that is not actually known, but based on 'belief' that the car has never been modified. You'll also need the proper cowl tag rivets for your replacement tag.
Old Apr 15, 2014 | 09:29 AM
dfire25's Avatar
970 for a drop top.
Pat
Thanks!
Old Apr 15, 2014 | 09:42 AM
kjr442's Avatar
Kjr442
True. I guess if someone wants to change things up a little , it can be done. This makes buying a high end car a little scary.
Old Apr 15, 2014 | 10:01 AM
Yes, it does. There are also vendors out there who will re-create build sheets and then carefully age them by saturating them with milk and then baking them against a seat spring. I saw that on the web once and it made me question the credibility of the seller. Makes you wonder about some of the provenance being flogged out there from time to time.
You're only replicating exactly what was there, so I don't see any issues with your project. I'm sure it would be a different story if the shop had lost your VIN and it needed replacing.....that would be a friggen nightmare IMO.
68 D88
Feb 11, 2014 07:23 PM
Scott Hamel
Sep 12, 2012 04:18 PM
SMILEYWATTZ
Mar 11, 2012 10:05 PM
Aceshigh
Apr 14, 2010 04:57 AM
Pfiffle
Oct 5, 2009 04:32 AM
