Blueprinting charts
Old Apr 1, 2012 | 08:32 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Blueprinting charts
I made up a quick bearing map if anyone wishes to use it while measuring their clearances.
It's pretty straight forward, but you will have to size the image to fit on one sheet of printer paper, and print out 3 copies.
1 copy for crank journals
1 copy for rod/crank housing bores
1 copy for rod/crank housing bores with bearing thickness taken into account.
You can write all of your measurements right on the paper, and circle whichever description you are measuring.
If you want to get really fancy, you can use 3 sheets just for the crank journals to determine if there is any taper.
Left , right, and center.
gearheads78
Feb 17, 2013 09:44 AM
pete324rocket
Nov 1, 2012 02:38 PM
coltsneckbob
Jul 12, 2009 09:41 AM
nonhog
Apr 22, 2008 10:05 PM
Jolly Green
Jan 31, 2008 08:59 PM
