Blower Motor Cage
Old November 3rd, 2014 | 06:13 PM
66-3X2 442's Avatar
Blower Motor Cage
Just wondering if anybody has had any experience in using a later model plastic blower motor cage in the early cars? Not sure if they fit or not but thought I might use one if it does. I figure the less weight on the motor the better. Then again it might not matter,thoughts?
Old November 3rd, 2014 | 06:53 PM
I doubt that it matters, so long as it's balanced. The weight difference will exist almost exclusively in terms of inertia, which will be felt only with changes in speed.
I believe that, if balanced, the fan will center itself in the bearing once it's spinning, so the slightly increased downforce on the front bearing shouldn't matter at all.
jeffsims
July 2nd, 2013 05:09 PM
mdavis9886
February 19th, 2012 04:46 PM
jozw30
January 9th, 2011 03:00 PM
bigbrother
May 18th, 2008 09:13 AM
docjcwatson
January 10th, 2007 02:46 PM
Quick Reply: Blower Motor Cage
