body mount cage bolts
Old May 16, 2008 | 04:20 PM
bigbrother's Avatar
69 cutlass vert. 4 trunk bolts and two bolts under front doors all spun. any suggestions on how to repair. should I go in from the top or bottom? The bolt heads have been drilled and the body is free from the frame.
PS. I hate rust.
BB
Old May 16, 2008 | 05:15 PM
Dapapadon's Avatar
I usually just grind the bolt head off with a 4-1/2" grinder. Then deal with what's left later. That's if you have room to get the grinder disc to it.
Don
Old May 16, 2008 | 05:19 PM
oldsconv's Avatar
Cage nuts
I cut a tab from the trunk sheetmetal from the top - same for ones by the doors. I replaced my floors anyway, so it was easy, but if you are keeping original floors, just cut 3 sides of a square and bend it up to access. Cut it out, sandblast and weld in new cage nut assembly (available from YearOne - let me know if you need part#). Then bend square tab down and weld in place. I was always scared of welding, but I bought a cheap wirefeed fluxcore and it has been invaluable versus trying to rivet things in.
Old May 16, 2008 | 05:55 PM
bigbrother's Avatar
Don, I'm already past the grinding off of the head.
Oldsconv, how big of a square did you cut? And will any grade 8 cage nut work as long as its the same as the bolt of course.
thanks BB
Old May 18, 2008 | 09:13 AM
oldsconv's Avatar
cage nuts
Not sure if my reply went thru the other day. Square hole is around 2 inch, but whatever size you need to access the recessed area where the cage nut is. Clean it up, sandblast and weld in a new cage nut. To clarify your question about grade 8, etc. The "cage nut" assembly is not a normal hardware store item. It is a square nut that floats inside a sheetmetal cage that is welded to the floor. The floating allows minor adjustment, but it is tight enough that when you tighten the bolt, the nut does not spin. Take a look at Year One's website, although you can probably buy these elsewhere. Their part# is G17NUT - search for it on their site and you will see a picture of the nut and cage. After you're done, paint it well to prevent rust (I used zinc paint) and then weld it back down.
nolabigdawg
Oct 25, 2014 11:50 AM
DewChugr
Jul 30, 2014 02:07 PM
mcutlass1969
Apr 23, 2014 05:14 AM
71cutlass350
Jan 7, 2014 12:34 PM
Kiwicutlass
Nov 25, 2012 02:33 PM
