body mount bolts 72 cutlass
Old Nov 24, 2012 | 06:17 PM
Kiwicutlass's Avatar
Just about to take my body off the frame 72 cutlass S Question how many bolts do you have to remove I have taken 8 out in total i see 4 other mounts which look to be sealed no bolts at the bottom .
any help appreciated
cheers
Old Nov 24, 2012 | 08:40 PM
Octania's Avatar
That sounds about right
If they look like body mounts but don't have a bolt, they are rubber pads.
not counting fwd of the firewall:
1 or 2 at the cowl
1 at the front seat area
1 at rear seat area ?
1 at the far back
each side of course
Old Nov 24, 2012 | 09:12 PM
Originally Posted by Kiwicutlass
Just about to take my body off the frame 72 cutlass S Question how many bolts do you have to remove I have taken 8 out in total i see 4 other mounts which look to be sealed no bolts at the bottom . any help appreciated
cheers
I'm guessing you don't have a 1972 Cutlass Assembly Manual? Here's what you're looking for. Don't worry that it shows a sedan, the mounts are the same for all Cutlass models
Old Nov 24, 2012 | 10:20 PM
Smile fr body mounts
Hi Guys
Got that all good have ordered a manual will be very helpfull all round
cheers
Old Nov 25, 2012 | 08:22 AM
Run to Rund's Avatar
There should be a couple more, if like a 1966. On each side, there are two at firewall, one each under door, behind rear wheel, and at back corner.
Old Nov 25, 2012 | 08:23 AM
The diagram above shows only one at the firewall on each side, but one bolted mount in front of the rear wheel. You can see access holes from the bottom of the frame for all hidden positions.
Old Nov 25, 2012 | 01:16 PM
And there are 2 at the radiator core support, different kit.
Old Nov 25, 2012 | 02:33 PM
re body mount bolts 72 cutlass
yep got the core support ones fell to bits 40 years of oil I guess
nolabigdawg
Oct 25, 2014 11:50 AM
DewChugr
Jul 30, 2014 02:07 PM
mcutlass1969
Apr 23, 2014 05:14 AM
71cutlass350
Jan 7, 2014 12:34 PM
bigbrother
May 18, 2008 09:13 AM
