Blower Motor Cage
Old Nov 3, 2014 | 06:13 PM
66-3X2 442's Avatar
Blower Motor Cage
Just wondering if anybody has had any experience in using a later model plastic blower motor cage in the early cars? Not sure if they fit or not but thought I might use one if it does. I figure the less weight on the motor the better. Then again it might not matter,thoughts?
Old Nov 3, 2014 | 06:53 PM
I doubt that it matters, so long as it's balanced. The weight difference will exist almost exclusively in terms of inertia, which will be felt only with changes in speed.
I believe that, if balanced, the fan will center itself in the bearing once it's spinning, so the slightly increased downforce on the front bearing shouldn't matter at all.
jeffsims
Jul 2, 2013 05:09 PM
mdavis9886
Feb 19, 2012 04:46 PM
jozw30
Jan 9, 2011 03:00 PM
bigbrother
May 18, 2008 09:13 AM
docjcwatson
Jan 10, 2007 02:46 PM
