Bleeding the convertible hydraulic lines
The convertible top hydraulic system recirculates the fluid, like your power steering pump. The lines are small enough that the fluid will be fully circulated by running the top up and down several times. Like Tedd says, make sure it is full and cycle the top a few times. No need to bleed it like your brakes.
Thanks for the tips gentleman. I should be good to go. I replaced one side several years ago with copper tubing instead of plastic and it's worked fine so I plan to do the same for the other side.
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
Classy 71
Jul 17, 2013 08:03 PM
