Big Block vs. Small Block Olds??
Old Dec 15, 2007 | 02:23 PM
bocoogto's Avatar
Why the two listings? All Olds V8's are the same external size like Pontiacs. I couldn't find any discussion about this on the forum. Did I miss something?
Old Dec 15, 2007 | 02:49 PM
GoldOlds's Avatar
Although small block vs. big block differences aren't as drastic with Olds as they are with Chevy, they DO have differences. Big block olds have a taller deck height (by about 1.3" I THINK). Therefore, you can't swap cranks, intake manifolds or pistons. Heads CAN be swapped between SBO and BBO, but you'll end up with smaller valves on your big block or bigger combustion chambers (less compression) on your small block. It's not quite like Pontiac, where everything from the 326 to 455 is interchangeable.
Hope this helps,
- GoldOlds
Old Dec 15, 2007 | 05:00 PM
Plus it makes things easier when posting. IMHO, there is no replacement for displacement. I would still rather run a SBO 307 than a SBC 350.
Old Dec 15, 2007 | 05:04 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Actually a 455's intake is over an inch wider.
Old Dec 15, 2007 | 06:13 PM
Oldsguy's Avatar
Past Administrator
Yes, again due to the taller deck height. With the rotating assembly being like an inverted traingle, the one with the longer sides will have a longer top, hence the wider intake, by about two inches I think.
Old Dec 15, 2007 | 06:30 PM
Yup. These are NOT like Pontiacs. As others have pointed out, the most obvious difference is deck height. The taller deck was required to fit the longer stroke, but main and rod bearings were enlarged as well. Rods are longer. Heads have larger ports. Intake and exhaust manifolds are different. Obviously, pushrods are different. Yes, there's a lot of commonality, such as cams, timing sets, motor mount location, distributors, but they are two different motor families.
Old Dec 16, 2007 | 04:22 PM
bocoogto's Avatar
Pontiac had two deck heights, too. The 301 and 267(?) had much lower decks than other Pontiac V-8's. Very little commonality of parts between these and the common Pontiac V-8's. In 1969/70, there was going to be a 366 Pontiac V-8 with Ram Air V heads. The block for these also was to be lower deck height. A few were built, but never saw installation on the assy. line. Many dealers, however, got complete 400 cu. in. Ram Air V engines on wood skids to sell to customers. I saw one at Wilde Pontiac in Waukesha, Wisconsin in 1970. It's the only factory Pontiac engine I ever saw with a Holley carb on it.
How about the 265 or 267 Olds engines from the early 80's? Were they the same dimensions as the 350 and 307?
Old Dec 16, 2007 | 10:24 PM
GoldOlds's Avatar
You mean the 260? I've never heard of an OLDS 265 or 267. If the 260 is the engine you're asking about, then yes, it shares the same dimensions with the Olds 307-330-350-403. The Olds 260 is a gutless engine, but probably still better than the Chev 267. At least the smallest SBO was somewhat reliable.
- GoldOlds
Old Dec 16, 2007 | 11:05 PM
88 coupe's Avatar
Junior Member
From post #1:
........ the same external size like Pontiacs ........
from post #7:
Pontiac had two deck heights ........
But, we are not here to discuss Pontiacs.
........ Many dealers, however, got complete [engines] on wood skids to sell to customers ........
It was/is not unusual for any parts department to order a "crate" engine for a customer. It has been done by all new car dealers, for as long as there have been car dealers.
........ Were they the same dimensions as the 350 and 307? ........
260, 307, 330, 350, and 403, all used the same 9.330" deck height.
Norm
Old Dec 17, 2007 | 06:47 AM
bocoogto's Avatar
88Coupe:
Postings show you do like to talk about Chevrolets. Please cut me a little slack on trying to understand Big Block vs. Small Block Oldsmobiles. I'm a Ponitac collector, and can better undersand to similarities to Oldsmobile V-8's. I would rather talk about Oldsmobiles than Chevrolets--wouldn't you prefer Pontiacs or even Buicks than Chevrolets for comparison??
Old Dec 17, 2007 | 08:23 PM
88 coupe's Avatar
Junior Member
........ you do like to talk about Chevrolets ........
You have me confused with someone else.
........ I'm a Ponitac collector ........
We could tell that from posts #1 and #7.
........ and can better undersand to similarities to Oldsmobile V-8's ........
They are both OHV 90° V8 ottocycle engines. Other than that, there are no similarities.
........ I would rather talk about Oldsmobiles than Chevrolets ........
In that case, I suggest you talk about Oldsmobiles, instead of Chevrolets.
........ wouldn't you prefer Pontiacs or even Buicks than Chevrolets ........
On an Oldsmobile site? None of the above.
........ for comparison?
Comparison of the lack of similarities?
Norm
Old Mar 6, 2008 | 10:06 AM
aliensatemybuick's Avatar
"me somebody" site member
I sure hope there is room for talk of Pontiacs on this site. I've been know to frequent the PerformanceYears Pontiac forum, since the rear in my 1965 Jetstar I is actually a Pontiac rear. Some of the window trim from my car (and also the 65-66 Starfires) was shared with the same year Grand Prixs...I ended up getting the trim pieces from someone over there in fact, and also got some useful info on the differential when I had probs with mine. I was up front when I visited there that I was an Olds owner, and they were very helpful. Least we can do is return the courtesy here, and by and far, I think that is what you will find.
Old Mar 6, 2008 | 01:51 PM
88 coupe's Avatar
Junior Member
Originally Posted by aliensatemybuick
I sure hope there is room for talk of Pontiacs on this site ........
No one here, said there is not.
I've been know to frequent the PerformanceYears Pontiac forum ........
We will not hold that against you, as no one here, has yet complained about my clandestine visits to Chevelles.com, Buick V8.com, Bonneville Club, or my Ford site.
since the rear in my 1965 Jetstar I is actually a Pontiac rear ........
As is the '57 rear in my Grey Coupe. Manufactured by Pontiac, and used exclusively in 57-64 Pontiac/Olds. For that reason (if, I was compelled to seek information an the internet) either site should be helpful.
........ Some of the window trim from my car (and also the 65-66 Starfires) was shared with the same year Grand Prixs ........
Many parts are interchangeable between GM divisions and their platforms.
........ Least we can do is return the courtesy here ........
No one here, has said we should not.
What is your point?
Norm
Old Mar 6, 2008 | 02:00 PM
Get help, buddy.
Old Mar 7, 2008 | 01:34 PM
Mister's Avatar
Post Obligatory FAQ link
There is a good (free) overview of Oldsmobile V-8 engines on the 442.com web site here: http://www.442.com/oldsfaq/ofeng.htm...964%20-%201990
Old Mar 7, 2008 | 06:11 PM
Rallye469's Avatar
Get help, buddy.
Norm!
In one post you said to talk about Olds rather than Pontiacs...
in the next you say it's OK to talk about them...
huh?
One usually can't argue with your technical acumen, but your
bedside manner is something else.
bocoogto...interesting stuff about the Ponitac engines. Love hearing about
the days when each division had an identity AND separate performance
divisions.
Managing to get things done in the shadow of big brother(chevrolet)
must have lead to some interesting things getting out the back door.
Old Mar 8, 2008 | 05:42 AM
66olds's Avatar
Hey Aliens, nice to see you at this forum.....
66olds...A.K.A. 66,425.......
Old Mar 8, 2008 | 01:31 PM
Hey, Dave, nice to "see" you here too.
Old Mar 8, 2008 | 06:35 PM
88 coupe's Avatar
Junior Member
........ In one post you said to talk about Olds rather than Pontiacs ........
Instead of making random accusations, follow the protocol that has been in place since before Algore invented the internet:
Which post? And what, exactly, did I say?
........ in the next you say it's OK to talk about them ........
........ One usually can't argue with your technical acumen ........
Not a problem. When/if I make a mistake, someone usually shows up to make the necessary correction(s). If it does not happen, any future visitors will be misinformed.
For those of you in Rio Linda, misinformation is a bad thing.
........ your bedside manner is something else ........
Common knowledge, both here and on several other sites. I take pride in the fact, that no one has ever accused me of being a Diplomat.
What is your point?
Norm
Old Mar 9, 2008 | 03:49 PM
Rallye469's Avatar
READY???
This will wind up in another argument over semantics...
ugh. Forget it...
Old Mar 10, 2008 | 08:05 AM
Warhead's Avatar
I think 88 is just bustin your *****!
Funny stuff.
Old Mar 10, 2008 | 10:54 AM
88 coupe's Avatar
Junior Member
READY??? ........
Interesting.
CAPs, bold, and multiple ???, at one time.
The "politically correct" version is, that the use of either CAPs or bold font can be perceived as “SHOUTING" and the use of multiple ??? are unnecessary.
In all three cases, I call it: Rude and immature.
As used, the word, itself could easily be taken as elitist, or insulting.
At this time, I choose to interpret these items, as a simple lack of communication.
........ another argument over semantics ........
Depending on the context, the word “argument”, can be defined as a positive discussion, as it is consistent with the goal of this site.
If everyone were to write exactly what they mean, and everyone read (in context) what is actually there, semantics could not possibly be an issue. Since misunderstandings can happen, they should be recognized as such and dealt with, in a calm/mature manner.
The word can also be applied to a childish pizzing contest.
Contrary to the popular misconception, my choice is always an adult discussion.
Norm
Old Mar 10, 2008 | 11:23 AM
Rallye469's Avatar
Are you a politician?
Doublespeak, avoidance, nebulous reasoning, rhetoric, mud-slinging...
the signs are all there.
Come on people, all together now... '88 in '08 !!!
Old Mar 10, 2008 | 12:26 PM
88 coupe's Avatar
Junior Member
Are you a politician? ........
No. Simply attempting to make a point, in a mature manner.
It is a given, that not everyone will grasp the concept of accurate communication, and that most will not even make an attempt to do so.
It is also a given, that you, and they, are not the the only members/visitors who will read this thread.
Norm
Old Mar 12, 2008 | 09:27 AM
DennisG.'s Avatar
As Larry the cable guy would say -
Now thats funny, I don`t care who ya are.
Old Mar 13, 2008 | 06:41 PM
88 coupe's Avatar
Junior Member
Originally Posted by Warhead
I think 88 is just bustin your *****! ........
I think you're right.
........Funny stuff.
And I think you're not the only one with that opinion.
Norm
Old Mar 18, 2008 | 04:56 PM
rrielley's Avatar
Don't we have a moderator to weed out the crap postings? It would be nice if the petty little arguments might get deleted and leave the postings that relate to cars. Olds or otherwise...
Old Feb 23, 2012 | 10:32 AM
The_Jeremiah's Avatar
Get help, buddy.
Obviously haven't spent much time talking to Norm.
he's not trying to make any enemies. Attitude is portrayed poorly through text... just my .02 cents
Old Feb 23, 2012 | 12:18 PM
Sorry to tell you:
Originally Posted by 66 Olznut
Norm passed away July 27th, I just found out via our local newsletter. He was one of the long time members, #54, joined in the mid 70s.
He is missed by many.
Old Feb 23, 2012 | 03:35 PM
Rickman48's Avatar
Sooo, who's the imposter?
And the point is?
Old Feb 23, 2012 | 03:51 PM
  #31
okie88's Avatar
Thanks for bringing this post up. Some of Norm's posts were classic. Sorry for those that didn't find his posts both informative and entertaining. I did.
Old Feb 23, 2012 | 03:55 PM
  #32
Impostor?
Jeremiah resurrected (pardon the term) a four year old thread to speak of Norm in the present tense.
I posted a link explaining that he had passed on in October (at least in part to forestall a discussion about his style amongst those who hadn't been aware of that).
The point is that responding to four-year-old threads as though you are responding to a post from four minutes ago can create confusion in the minds of other members.
Old Feb 23, 2012 | 04:20 PM
  #33
Wow, 2008, who dredged this up? I agree Norm was a classic and I don't believe he can ever be duplicated! He will be sorely missed but never forgotten!
Old Aug 26, 2023 | 06:09 PM
  #34
trapoc's Avatar
Hey can I get in on this post? sounds like it could come alive again.
TicTocTach
Jan 31, 2014 10:19 AM
landbarge
Jan 30, 2012 12:02 PM
antweave
Apr 22, 2011 11:32 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
