Battery Cable Question
Old Dec 7, 2022 | 04:20 PM
Bigmikey65's Avatar
In the attached diagram from the 1970 CSM, what does “A.M.T.” and “S.M.T.” stand for ? I’m’ guessing the M is for Muncie ?
Old Dec 7, 2022 | 04:51 PM
442Harv's Avatar
Auto tran and manual tran.
IIRC, Automated Manual Transmission and Standard Manual Transmission (maybe synchronized Manual Transmission. Predecessor was an AST Automatic Safety Transmission)..
Old Dec 7, 2022 | 05:38 PM
Loaded68W34's Avatar
Correct, the "A" is for automatic and the "S" is for standard (manual). The cable goes up over the valve cover on manual cars to keep it away from the clutch linkage.
Old Dec 7, 2022 | 05:52 PM
But he asked what the “M” is for. The M stands for Manual. A is “Automated”
Old Dec 7, 2022 | 06:07 PM
rocketraider's Avatar
Oldsdruid
AMT- Auto Matic Transmission
SMT- Synchro Mesh Transmission
You will sometimes see automatic transmission designated HMT Hydra Matic Transmission or JT Jetaway Transmission.
Old Dec 7, 2022 | 06:15 PM
Actually he asked:
"In the attached diagram from the 1970 CSM, what does “A.M.T.” and “S.M.T.” stand for ? I’m’ guessing the M is for Muncie ?"
He did not just ask what the "M" is for. I could be wrong, but I took the meaning of his question to be: Why is the routing different for "SMT" and "AMT"? and that he was only postulating "M" might stand for Muncie (which as you said it does not) but was also unsure of what "A", "S", and "T" were for.
Old Dec 7, 2022 | 06:55 PM
It's worth pointing out that it is better for the cable to be run on the fender from a heat endurance perspective. Otherwise, they'd all be on top of the valve cover like the manual transmissions.
Old Dec 8, 2022 | 06:02 AM
Bigmikey65's Avatar
Was curious about what “A.M.T.” and “S.MT.” actually stood for. I knew from others which way the cables were supposed to be installed. But looking at the diagram how can you be 100% sure unless you’re 100% sure what those 2 groups of 3 letters actually stand for.
Old Dec 8, 2022 | 07:55 AM
Oldsdruid
All the factory parts books have a list of abbreviations used in the parts descriptions.
Bigmikey65
Dec 6, 2022 04:44 PM
Chuxter
Oct 28, 2022 10:59 AM
Platinum69
Mar 19, 2020 05:17 PM
Platinum69
Nov 2, 2018 02:30 PM
rktolds
Nov 8, 2014 06:53 AM
