Bad th350 kickdown cable ?
Old Feb 19, 2014 | 03:58 PM
Al Sanchez's Avatar
I have a 1972 cutlass with a th350 transmission and I can't seem to be able to adjust the kickdown cable.. I think I'm missing the part that goes on the cable that is adjustable.. here are some pictures of my cable.. is the part that is missing on my cable replaceable? if it's not does some one have a correct picture of one that is not installed on the car they can lay out and take a picture of.. I want to go to the junkyard and see if I can find one.. if I don't find one I may have to post that I need one in the wanted section
Old Feb 19, 2014 | 04:13 PM
Heres a link to a complete cable assy.
http://www.supercarsunlimited.com/Tr...bles-i428.aspx
Here is a link for the adjustment:
https://classicoldsmobile.com/forums...cutlass-s.html
Old Feb 19, 2014 | 04:15 PM
70cutty's Avatar
Beer Connoisseur
Your cable looks OK. Why do you think you need to adjust it?
Old Feb 19, 2014 | 04:28 PM
Al Sanchez's Avatar
Thanks, I guess mine is missing that piece that looks like a plastic tube that the cable goes thru.. ... the new cable 70.00 plus shipping... junkyard here I come
Old Feb 19, 2014 | 04:36 PM
Al Sanchez's Avatar
70cutty, some times I felt that my kickdown cable was not working right so I took a look at mine and I did a little research to see if it has any kind of adjustment and I guess it need mine is missing the piece the suppose to be self adjustable, as you can see in my pictures where it connets to my accelerator my cable end is just sitting there lose
Old Feb 19, 2014 | 04:43 PM
Yes, it looks lie your missing the tube. There may be a less expensive source for it. Hell OPGI was $99, perhaps someone has a clip.
Old Feb 19, 2014 | 05:00 PM
Al Sanchez's Avatar
Thanks, Eric.. now I need to see if that piece is replaceable as I can't find anything saying that it is
Old Feb 19, 2014 | 05:02 PM
70cutty's Avatar
Beer Connoisseur
I took mine out few months ago. I am gonna check the garage later hopefully I didn't throw it away. If I find it it's yours.
Old Feb 19, 2014 | 05:09 PM
Al Sanchez's Avatar
Cool, thanks, did you install a different transmission on your car ?
Old Feb 19, 2014 | 05:38 PM
70cutty's Avatar
Beer Connoisseur
No, did a few things to my th-350 in anticipation of the new engine.
Old Feb 19, 2014 | 05:44 PM
crank shaft's Avatar
Detent cable
Do yourself a favor, If you have to get a new one get the GM one. I purchased the cheaper one and installed it, The trans did not shift right and if it stays applied you could smoke the trans. I replaced it with the GM one from the Parts place and all is good!
Mike
Old Feb 19, 2014 | 07:33 PM
Al Sanchez's Avatar
Mike, thanks for the heads up, I did look at the one from the parts place and I think ill go with that one if I can't find one soon
Old Feb 20, 2014 | 03:18 AM
The GM one worked well for me, the aftermarket one is to short. And also I noticed that with the exhaust system so close to the plastic mounting flange it gets soft from the heat. It also kept the valve open and this could ruin your tranny! Mike.
Old Feb 20, 2014 | 04:33 AM
NDERISE's Avatar
sleeve missing
I see why u have no down shift the rubber sleeve that goes over the boss at the accelerator end of the cable is missing. there is a rubber hose (sleeve) that slides over the ball at the end of the cable. it is like a stiff rubber hose that slides over the ball and when the throttle is pushed to the floor for the first time it positions the sleeve over the ball which pulls the cable tight on the down shift valve. try putting a vacuum hose over the ball, cut it about 2 inches long the hose should fit tight on the ball so as to it will stay in place. I have repaired cables this way in the pass.
ray
Old Feb 20, 2014 | 06:33 AM
4speed455's Avatar
I got a replacement cable for my th350 from advance auto for less then $20. http://m.advanceautoparts.com/mt/sho...n_jtt_redirect
Old Feb 20, 2014 | 09:43 AM
Al Sanchez's Avatar
Thanks for the input guy's. Wow from 20 to 100 dollars. I'm goin to hit the junkyard and see if I can find a good original one, I'm putting the car up for sale so I really don't want to rig up the one it has now, the one from Advance auto is a good price,
Old Feb 26, 2014 | 01:12 PM
eazy's Avatar
From: Malvern, PA (Hometown) Williamsport, PA (College)
I bought mine from year one it was $97 shipped. That was pretty much the best price I could find for something that listed the correct year range (68-72). In the process of putting it in...
Old Feb 26, 2014 | 03:10 PM
Al Sanchez's Avatar
https://classicoldsmobile.com/forums...detent-ca.html here is another thread I accidentally started it talks about the two different types of kickdown cables, they both will work
nj67
Jul 25, 2014 04:08 AM
yeahbuddy
Apr 4, 2012 09:54 AM
bigbrother
17
Mar 11, 2012 06:45 PM
archerbob
Sep 12, 2011 01:29 PM
mark8918
Feb 6, 2009 09:34 AM
