Axles for Flange Style (non C clip) 8.5" 10 bolt
Old June 13th, 2016 | 10:22 AM
t_huth21's Avatar
Hey there all. Does anyone know if there is a source for axles for a flange retained (non C clip) 8.5" 10 bolt rear end? Seems if you look on Summit or places of the like, c clip axles are all that are available. I'm looking for one axle half ways on the cheap. It's looking like it may be a special order at this point which will obviously be $$$. Any insight would be appreciated. Thanks
Old June 13th, 2016 | 10:32 AM
One of the folks on here may have a used one. The speed vendors don't support bop parts very well.
Old June 13th, 2016 | 10:56 AM
Moser can make any axle shaft you want.
If you want "cheap", then you want used.
Old November 28th, 2016 | 11:30 AM
HWYSTR455's Avatar
Looks like I need to replace an axle as well.
Does anyone have the correct dimensions for a 71-72 A body non c-clip axle?
Old November 28th, 2016 | 11:55 AM
Gary M's Avatar
8.5
My axle was just rebuilt and axles are not installed yet. I can draw it and post deminsions. It's a 72 SA B xxx maybe tonight.
Old November 28th, 2016 | 12:22 PM
HWYSTR455's Avatar
Who rebuilt them? Do you mean you had someone like Moser make you new axles?
Yes, measurements would be fantastic! Please!
-Mike
Old November 28th, 2016 | 12:32 PM
Dave Pastrick's Avatar
I have a NOS non C-clip axle shaft but don't know what it firs. Found it in an Oldsmobile dealers attic many years ago in a non GM box marked 5.420 / 1254369 so don't know if this number is correct. This number is not in my 66/67 parts book. It has a 5x4 3/4 bolt pattern, 28 splines and measures 26" from bearing retainer to spline end and is 1 3/4" diameter at spline end. If anyone is interested call me 630-730-6614. I have had it a long time and it needs to find a new home!
Old November 28th, 2016 | 12:35 PM
Dave,
That looks like 1973-77 A-body (except wagon) with B or O type axle.
Old November 28th, 2016 | 12:54 PM
Gary M's Avatar
Had posi , new bearings, etc put in existing unit. Axles are not new. He did not put axles into housing because I am installing disk brakes on the rear. The measurements will be of old usable axles with bearings on them.
Old November 28th, 2016 | 02:24 PM
gbledsoe3's Avatar
I used these folks to resurface my axle flanges and install new 3" studs. Give them a call.
http://www.dutchmanaxles.com/
Old November 28th, 2016 | 02:50 PM
gbledsoe3's Avatar
Old November 28th, 2016 | 03:32 PM
HWYSTR455's Avatar
I've used Dutchman before for driveshafts, they are great when it comes to customer service and turn around.
And wow, they actually list a replacement factory type axle:
http://www.dutchmanaxles.com/bop-sto...ob-single.html
They say they have sealed type bearings too, now I'm going to have to look and see if they are correct or not. Sweet.
Thanks for the link! I will look into this further and post my findings!
Old November 28th, 2016 | 07:53 PM
Gary M's Avatar
Axle measurement.pdf
Old November 29th, 2016 | 07:46 AM
That's a good drawing, but the surface that the bearing and retaining ring press onto needs to be specified to a much tighter precision than 1 7/8". It's this press fit that retains the axle and you need to be correct within a couple of thousandths.
Old November 29th, 2016 | 07:56 AM
Inline's Avatar
Monzaz from this site sells those flange-type axles too, just bought a pair from him.
My other axle wasnt at best shape, and since they werent even pairs to start with ( other has been changed at some point) i thought id replace both for the sake of having everything new at the rear.
Hes absolutely best guy ive ever dealt when doing business, i highly recommend him.
Have bought everything from him whats inside the rear housing.
You can contact him too at www.jdrace.com
Old November 29th, 2016 | 10:40 AM
Gary M's Avatar
Thought he needed to know rough size to buy correct used one.
Old November 29th, 2016 | 05:36 PM
HWYSTR455's Avatar
I need exact measurements, since I need to have an axle made.
The bearing area I believe is 1.380, and the inner dimension for the A9 bearing is 1.375. But I think I can get that info from Dutchman.
Might be able to get other dimensions from Dutchman too, and may use that to order from Moser, so I have a matched pair. (Not that it really matters)
Old November 29th, 2016 | 06:06 PM
Gary M's Avatar
My bad
They already pressed the bearings on mine.
Old February 24th, 2017 | 09:49 AM
brownbomber77's Avatar
A few months old, but there's a place in Brandon, just north of me, that has a set of axles removed from a cutlass.
http://www.ebay.com/itm/252174915042...%3AMEBIDX%3AIT
Old February 24th, 2017 | 10:09 AM
HWYSTR455's Avatar
Interesting, I just not 2 hours ago ordered an axle from Dutchman!
I need a 30 spline though, have a Tru-Trac diff in it. But good info!
Your Order #100xxx61 (placed on February 24, 2017 8:37:35 AM MST)
Old February 24th, 2017 | 10:31 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Guys, there are several guys here in the classified section that make a living selling used Olds parts. Bet the farm there are several 8.5 O style axles for sale.
t_huth21
June 1st, 2016 10:56 PM
yankees
June 13th, 2013 04:16 PM
yankees
Drivetrain/Differentials
June 11th, 2013 07:24 AM
72442conv
March 19th, 2012 08:14 AM
81 regency
April 21st, 2011 07:18 PM
