Anyone installed these headlights yet?
Old Jan 24, 2015 | 11:37 AM
GINCSC's Avatar
https://www.xtremeledsonline.com/sto...-Headlight-Kit
Classic Four 5 3/4 inch LED Headlight Kit $299.99
Old Jan 27, 2015 | 02:00 AM
Aceshigh's Avatar
Many people are selling these aftermarket LED housings that are not DOT street legal.
Can you see the glare coming off them from an elevated position where the picture was taken???
That means oncoming drivers will be blinded by the glare coming off these. That light beam shouldn't scatter THAT high.
They are not designed properly, so no I wouldn't buy them.
You will get the same result from putting HID bulbs into a halogen designed housings......insane glare and not legal.
More importantly they are dangerous to other drivers on the road.
Old Jan 27, 2015 | 04:25 AM
jozw30's Avatar
Not sure if they have them in the smaller diameter, but search for the newer projector type and filter out anything below $250.00 then again for DOT approved products.
Old Jan 27, 2015 | 09:11 AM
RetroRanger's Avatar
72 Olds CS
The marketing text says designed to dot standards but not dot listed....I wonder does that mean it meets dot standards? My guess would be no I think the text was added and carefully worded to make it seem like it could meet dot standards, but doesn't.
Old Jan 27, 2015 | 07:36 PM
DewChugr's Avatar
Photoshop God
This place has DOT compliant LED headlights, but only 7" size.
Old Jan 27, 2015 | 09:46 PM
Mr Nick's Avatar
Junk.
Do an H4 conversion with dual relays and you will be amazed. I can see into the future with my high beams.
Old Jan 28, 2015 | 09:10 PM
Aceshigh's Avatar
^ Agreed.
Samething I did. The rest is just wallet liquidation for non-DOT ignorance to other drivers.
........ and I'm a Mod junkie.
Old Jan 28, 2015 | 09:34 PM
dads72's Avatar
Great information guys...is there a kit out there somewhere for what you guys did? We are doing a frame off on my '72 and I am in parts buying mode right now. Will have a whole new harness from painless...
Old Jan 28, 2015 | 09:48 PM
Mr Nick's Avatar
These:
http://www.summitracing.com/parts/hla-002425811
http://www.summitracing.com/parts/hla-002850811
and this:
http://www.ceautoelectricsupply.com/...relaykits.html
Old Jan 29, 2015 | 02:30 AM
cdrod's Avatar
Rodney
glass or plastic?
Nick:
Thanks for sharing the Summit links. I've been considering this conversion for my project (especially the relays) but didn't think to check Summit. I have 2 questions for you:
1. Do these Hellas kits have glass housings or are they plastic?
2. Did you have to modify your headlight buckets to install them?
Old Jan 29, 2015 | 05:37 PM
Mr Nick's Avatar
They are glass, very nice quality. I did have to cut the headlight buckets open to allow the bulkier glass housing to fit. I used some sheet metal sheers and repainted them.
I also had to elongate one of the notches in the headlight buckets to fit the 3 tabs on the headlight that keep it clocked in the correct position.
The curve between the high and low beam housing is slightly different, which is needed so the lows beams are short and wide pattern, and high beam is longer and narrow.
I was afraid this detail would stand out and annoy me, but unless I'm actually crouched down looking at them, it's not even noticeable.
Old Jan 29, 2015 | 07:41 PM
cdrod's Avatar
Rodney
Nick:
Those lenses are much flatter that the old T3 style, and the back sides are hugh compared to the OEM bulbs. Where did you mount the relays for the wiring harness?
Old Jan 29, 2015 | 08:05 PM
DewChugr's Avatar
Photoshop God
They say HIR bulbs are quite a bit brighter.
Old Jan 29, 2015 | 09:52 PM
Mr Nick's Avatar
Relays are mounted to the core support area behind driver side headlight.
Old Jan 30, 2015 | 10:04 AM
GINCSC's Avatar
Great information Guys!!!
Thanks for your replies.
I was looking into LED so no reply's are needed. I'm sure someday soon there will be a dot approved LED.
Gincsc
ent72olds
Non-Olds Engines
Feb 20, 2012 10:13 PM
RAMBOW
Jul 2, 2010 07:34 PM
gearheads78
Site Suggestions
22
Sep 21, 2009 03:49 PM
geckonz08
Aug 21, 2008 07:58 PM
